Old 02-13-2013, 17:42   #1 (permalink)
moinuddin111's Avatar
Member: 864102
Sonork: 100.1617637
Thanks Meter: 146
Arrow samsung e1282t imei repeire problem.
samsung e1282t imei repaire problem.
HI TEAM,
E1282T HAS IMEI 000000.
WHEN TRY TO REPAIR IMEI IT SAY REPAIR DONE .BUT IMEI STILL 00000.
HERE ARE THE LOGS.
Selected model: E1282T
Selected port: COM36 Z3X BOX Serial Port
Selected port speed: 921600
Waiting phone... detected COM9
Sending FDL... OK
Reconnecting phone... OK
Reading NV... OK
Checking NV... OK
IMEI Master: 000000000000000
IMEI Slave: 000000000000000
Phone HW:
Product code:
Sending NV... OK
Repair done
Done with Samsung Tool v.13.9
The Following User Says Thank You to moinuddin111 For This Useful Post:
Old 02-21-2013, 05:21   #2 (permalink)
Member: 864102
Sonork: 100.1617637
Thanks Meter: 146
why not give me solution z3x team plz help me i m wating.
Old 02-27-2013, 08:26   #3 (permalink)
Member: 1107485
Thanks Meter: 73
yes sir............. i am also waiting........please help.z3x team.... thanks........
Old 02-27-2013, 09:19   #4 (permalink)
Member: 1004995
Thanks Meter: 230
Dear
No one will reply .
Old 02-27-2013, 09:25   #5 (permalink)
chandan_123's Avatar
Member: 801212
Sonork: 100.1657902
Thanks Meter: 773
Z3x team suport plz..................
Old 03-07-2013, 12:39   #6 (permalink)
quasim0438's Avatar
Member: 237155
Thanks Meter: 415
i have also tried both flash mode and at mode options and with original imei no. but failed to repair
Selected port: COM32 Z3X BOX Serial Port
Waiting phone... detected COM107
Sending FDL... OK
Reading NV... OK
Checking NV... OK
Phone HW:
Product code:
Sending NV... OK
Repair done
Done with Samsung Tool v.14.0
Sending FDL... OK
Reading NV... OK
Checking NV... OK
Phone HW:
Product code:
Now power ON phone and connect to USB cable
Searching Samsung modem... detected COM105
Reading phone info...
Model: GT-E1282T
Country code: KOR
Cal date: 11-10-2012 23:28:38
Factory SW: E1282TDDLK2
Unique number: 965462D4322D375B
Memory phone: GD25Q64
Bypass MSL... error
Old 03-10-2013, 03:52   #7 (permalink)
quasim0438's Avatar
Member: 237155
Thanks Meter: 415
pleae check this problem and solve it asap.
Old 03-10-2013, 14:08   #8 (permalink)
blang's Avatar
Member: 2368
Sonork: 100.111111
Thanks Meter: 186,554
flash normal firmware. only after this you can imei repair.
Old 04-06-2013, 06:58   #9 (permalink)
Member: 859435
Sonork: 100.1637124
Thanks Meter: 10
E1282t flashing after imei damage.000000
sir plz check log hare,
Selected port: COM5 Z3X BOX Serial Port
Waiting phone... detected COM7
Sending FDL... OK
Reading NV... OK
Checking NV... OK
Phone HW:
Product code:
Searching Samsung modem... detected COM44
Model: GT-E1282T
Country code: KOR
Unique number: 436462D42B26304F
Bypass MSL... error
Done with Samsung Tool v.14.2
Done with Samsung Tool v.14.2.
sir plz check this log and any working solution.Thanks.
Old 05-03-2013, 15:06   #10 (permalink)
Member: 893550
Thanks Meter: 139
first flash phone with z3x file then repair imei
Old 05-22-2013, 07:38   #11 (permalink)
Member: 945450
Sonork: 100.1640304
Thanks Meter: 35
samsung e1282t imei repeire problem. solved
E1282T JPLK4 - Download - 4shared
then open it (Avator/dragon tool) Select SPD
After Select Spd Select this file in Directory
then select IMEI and press run A new window is show insert ur og set imei here
and press rebuild a new file save same Directory name such as (rebuild_imei_E1282T)extra
write this file use volcano/miracle tool your imei is back og
this is tested 1000%
it self
Old 05-22-2013, 07:55   #12 (permalink)
Member: 945450
Sonork: 100.1640304
Thanks Meter: 35
then open it (Avator/dragon tool) Select SPD (SPD imei repair old Method)
and press rebuild a new file save same Directory name such as (rebuild_imei_E1282T)etc
it self
The Following 2 Users Say Thank You to sammar_707 For This Useful Post:
Old 06-23-2013, 08:13   #13 (permalink)
Member: 291960
Thanks Meter: 18
flash e1282t only in 115200 in any tool z3x or volcano.
z3x flash in any speed but can successfully in only 115200.
other tool can'tstart flash in other speed.
easyest way is
1. flash with z3x in 115200
2. change imei in flash mode speed 115200.
100% solution
Old 09-05-2013, 02:42   #14 (permalink)
Member: 550622
i do every thing but the same imei is still there > i want to change imei please help meeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
Old 11-08-2013, 14:22   #15 (permalink)
farsi_007's Avatar
Member: 472592
Sonork: 100.1664052
Thanks Meter: 180
samsung e1282t succefully flashed with volcano
flash it with volcano
here is procedure
http://forum.gsmhosting.com/vbb/f723...ml#post9863509
Page generated in 0.25616 seconds with 8 queries
