12-03-2011, 07:49 | #1 (permalink) |
No Life Poster Join Date: Jan 2010 Location: Bangladesh Age: 34
Member: 1217931 Status: Offline Sonork: 100.1604251 Thanks Meter: 267 | Samsung E2220 unlock Problems Selected com port: COM13 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone SW: E2220XXKJ1 Phone CSC: E2220P4UKJ5 Phone BT ADDR: D0DF-C7-931B5B Phone IMEI: 35821404526316 Deactivated MSL - FAIL Elapsed time: 21 second, sw ver: 3.5.0029 |
12-12-2011, 09:15 | #6 (permalink) |
Freak Poster Join Date: Apr 2006
Member: 255638 Status: Offline Thanks Meter: 10 | This solution is 1000000000%ok -------------------------------------------------------------------------------- Those who have problem to unlock e2220 here is the solution. 1.In z3x box select model e2222. 2.Go to setting model tab and tick flash mode and use usb. 3. Remove batt from phone and hold 2+4+5+8 keys at same time and install c3303k high speed dfu driver. 4.Press direct unlock wait near 1min done. Thanks z3x team here is the log. Selected model: E2222 Selected com port: COM7 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A34 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Erasing... OK Sending... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 125 second, sw ver: 3.5.0029 |
12-13-2011, 10:41 | #7 (permalink) | |
Insane Poster Join Date: Jan 2006
Member: 218868 Status: Offline Thanks Meter: 5 | E2220...works...TESTED Quote:
The Following User Says Thank You to omarSA For This Useful Post: |
12-16-2011, 05:37 | #9 (permalink) | |
Freak Poster Join Date: Aug 2005
Member: 172543 Status: Offline Thanks Meter: 126 | Quote:
just press A+S then connect usb cable | |
The Following 2 Users Say Thank You to appolo For This Useful Post: |
01-14-2012, 21:55 | #11 (permalink) |
No Life Poster Join Date: Mar 2006 Location: Bulgaria Asenovgrad Age: 42
Member: 239176 Status: Offline Sonork: 100.1602815 Thanks Meter: 851 | working..... Selected model: E2222 Selected com port: COM3 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A34 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Erasing... OK Sending... OK Unlock - ok If lock - not deactivate: Please make full reset *2767*3855# + input code #7465625*638*00000000# Elapsed time: 156 second, sw ver: 3.5.0030 need to press and hold key 4 and 5 insert usb and unlock select tab setings flash mode ------------------------------------------------------------------------------- Selected model: E2222 Selected com port: COM3 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A34 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Phone master IMEI -> 35841204974945 Phone slave IMEI -> 35841304974945 Phone SW -> E2222XXKE2 Langpack-> Austria, Belgium, France, Germany, Hungary, Italy, Spain, United Kingdom Phone HW -> MP 0.400 Phone BT ADDR -> E4B0-21-A1A1D9 Read Info - ok Elapsed time: 102 second, sw ver: 3.5.0030 ------------------------------------------------------------------------------- |
The Following User Says Thank You to delchoni For This Useful Post: |
01-18-2012, 18:51 | #12 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Lahore Pakistan. Age: 38
Member: 1284347 Status: Offline Sonork: 100.1592292 Thanks Meter: 977 | imei is ok but not unlock Selected model: E2222 Selected com port: COM33 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A34 Sending loader... OK Connect to control pipe... OK Connect to write pipe... OK Connect to read pipe... OK Damping... OK Phone master IMEI -> 00000000000000 Phone slave IMEI -> 00000000000000 Phone SW -> E2220CEKI1 Langpack-> Austria, Belgium, France, Germany, Hungary, Italy, Spain, United Kingdom, Portugal Phone HW -> MP 0.400 Phone BT ADDR -> 0012-47-000001 Read Info - ok Elapsed time: 105 second, sw ver: 3.5.0032 |
01-28-2013, 13:57 | #13 (permalink) | |
Freak Poster Join Date: Dec 2010
Member: 1463928 Status: Offline Thanks Meter: 11 | Working perfectly!! When this model have user lock code at start just this solution can be used, when not TAT is ok. Thanks! Quote:
09-03-2013, 16:52 | #14 (permalink) |
Freak Poster Join Date: Mar 2013 Location: http://forum.gsmhosting.com
Member: 1892345 Status: Offline Thanks Meter: 12 | E2222 NOT FOUND Selected model: E2200 Selected port: COM16 Z3X BOX Serial Port Selected port speed: 921600 Waiting phone... not found Done with Samsung Tool v.15.3 Done with Samsung Tool v.15.3 |
09-06-2013, 16:10 | #15 (permalink) | |
Member: 1892345 Status: Offline Thanks Meter: 12 | Quote:
Selected com port: COM16 Selected speed port: 921600 Press "volume down" + "lock" and connect USB cable to phone Connect to control pipe... FAIL Send loaders - fail Elapsed time: 36 second, sw ver: 3.5.0040 | |
$50 Reward for unlocking my 6150!!! | TheDon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 03-23-2015 14:21 |
