04-05-2013, 10:44 | #2 (permalink) |
Major Poster Join Date: Jan 2012
Member: 1711037 Status: Offline Thanks Meter: 8 | - First you have to install USB drivers by click on Setup.exe inside this Folder: Sunstone_V5_00_0_1_WHQLed - Power on the phone and connect USB cable to it and to PC to let Windows install its drivers. - Turn off the phone and connect USB cable to it and to PC to let Windows install its drivers. - Run the E2222 Ch@t Flasher: Flash loader 7.4.7_SSG_v0.1_Lite.exe - Click SET MODEL button and select: E2222_TEXTO_Setting_v00.mdl - For Application Binary File select: E2222xx.ptt - For Tfs file select: E2222xxxxx.tfs - For CSC file select: E2222Oxxxxx.csc - Turn off the phone and connect USB to it while pressing Q + A keys to install DFU mode drivers. - Disconnect the phone after DFU drivers installed. - Click START button and reconnect USB cable to phone while pressing Q + A keys. - The program will detect it and start the Update Process so wait till all is DONE. - Disconnect the phone and turn it on then do Full reset: *2767*3855# |
04-05-2013, 13:41 | #3 (permalink) | |
Freak Poster Join Date: Jul 2011 Location: India. Karnataka
Member: 1620410 Status: Offline Thanks Meter: 47 | Quote:
