samsung e2252 unlocking problem helloo support team samsung e2252 dual sim not unlocked with z3x :confused: . i try to use uart cable but not any responce . also not any guidence add for unlocking & flashing :confused:. plz help support team its urgent . thanxx |
try this code brother, not sure but just try and tell me the result *2767*2878# |
showing any emergency call options? |
bhai phone lock ma code kasa lagaga |
Download version 3.5.0022 of tool, then retry, you should be able to unlock only with usb cable. Post result and log here. |
not sucsess bro ....are u try your method ???? i try with uart cable but no responce .........can u tell me procudure that how to unlock and flash this samsung e2252 ............witch cable i use.......thanks in advanced...... |
Read what I wrote : POST YOUR LOG or don't cry for help. |
1 Attachment(s) Quote:
here is screen shoot bro i try unlock but not sucsess because uart cable not responce i try 5 more cables .....after then i try flash usb cable but not sucsess plsss give me solution |
finlally sucseesfully change imei by me its a simple trick and here is screenshot method is simple 1st conect cable and press power buton shortly set is on then remove betrry and put again and press power buton just a second phone screen show tat mode and imei sucseesfully change............ sucsess log2.JPG - 4shared.com - photo sharing - download image |
Selected model: E2252 Selected com port: COM13 Selected speed port: 921600 Please, connect phone and press power button 3 seconds Phone Detected Use automatic parameters Phone in TAT MODE Phone master OLD IMEI: 35*********** Phone slave OLD IMEI: 35************* Phone SW: E2252DDLG2 Phone CSC: E2252ODDLG2 Phone BT ADDR: D857-EF-36F46D Phone SN: RV1C774GCW Unlock - ok Elapsed time: 38 second, sw ver: 3.5.0038 -------------------------------------------- |
samsung e2252 not flashing with z3x ------------------------------------------------------------------------------- Selected model: E2252 Selected com port: COM3 Selected speed port: 921600 Press "1" + "3" and connect USB cable to phone Connect to control pipe... OK Processor ID -> 0A35 Sending loader... OK Connect to control pipe... FAIL Send loaders - fail Elapsed time: 66 second, sw ver: 3.5.0038 |
