02-12-2017, 08:56 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | samsung f925f securty damaged error help me New Securiry Type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. 6. Press 'Read codes' button and select 'Read codes New' to read security codes. Old Securiry Type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. 5. Press 'Read codes' button and select 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Unlock Selected model: SM-G925F Software version: 27.7 Waiting ADB device... OK Reading phone info... Model: SM-G925F Android version: 5.0.2 Product code: Phone version: G925FXXU1AOD8 PDA version: G925FXXU1AOD8 CSC version: G925FXFV1AOD9 CSC country code: South Africa CSC sales code: XFV HW version: Phone SN: R58G41QRQFN Chip name: EXYNOS7420 Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.7 |
02-12-2017, 09:34 | #2 (permalink) | |
Registered User Join Date: Dec 2015 Location: Chittagong, Bangladesh
Member: 2506300 Status: Offline Thanks Meter: 345 | Quote:
