Old 09-06-2017, 12:58   #2041 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 456
FLASH INSTRUCTIONS:
1. Choose correct flash file(s).
2. If you have PIT file chosen, then you must check 'Repartition' option.
3. Check flashing options if needed (Repartition, EFS clear, Boot update).
4. Power on the phone in download mode (turn off phone, press vol.down + home + power).
5. Connect the phone to PC with USB cable, install drivers if needed.
6. Press 'Flash' button.
Operation: Flash
Selected model: SM-G901F
Software version: 29.2
File analysis... OK
Total file size: 0xF925B15C (3986 Mb)
Searching USB Flash interface... COM74 detected
Setup connection... OK
Set PIT file... OK
Reading PIT from phone... OK
Sending aboot.mbn... OK
Sending sbl1.mbn... OK
Sending rpm.mbn... OK
Sending tz.mbn... OK
Sending sdi.mbn... OK
Sending NON-HLOS.bin... OK
Sending boot.img... OK
Sending recovery.img... OK
Sending system.img.ext4... OK
Sending persist.img.ext4... OK
Sending userdata.img.ext4... OK
Sending modem.bin... OK
Sending cache.img.ext4... OK
Sending hidden.img.ext4... OK
Flashing done (time - 00:12:53)
Done with Samsung Tool PRO v.29.2
Old 09-06-2017, 18:17   #2042 (permalink)
ghacks's Avatar
Member: 1196914
Sonork: 100.1667938
Thanks Meter: 1,645
UNLOCK INSTRUCTIONS:
Unlocking with original MSL code:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't unlock this phone with MSL.
1. Phone must be powered on.
2. Run dialer and type *#0*# (service mode will apear).
3. Connect the phone to UART cable, choose correct COM port in port settings.
4. Press 'Unlock' button.
5. Paste MSL code in new opened window and press 'OK'.
Reading codes using sever:
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read Codes via server' button, write your login and password in window if it will apear.
(Login and password will be saved as default after first input and can be changed in settings.)
To reset Google account activation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP' and follow the instructions in program.
5. When process done, press 'Back' on phone and perform factory reset from phone settings.
To reset Google account activation or Samsung reactivation lock:
1. Power on the phone in download mode (turn off phone, press vol.down + home + power).
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
4. After phone reboot, go to settings and perform factory reset.
Operation: Reset FRP
Selected model: SM-J320VPP
Waiting ADB device... OK
Reading phone info...
Model: SM-J320V
Android version: 6.0.1
Product code: Not Active
Phone version: J320VVRU2APE1
PDA version: J320VVRU2APE1
CSC version: J320VVZW2APE1
CSC country code: USA
CSC sales code: VZW
HW version: J320V.03
Phone SN: R28H83ETQYD
Chip name: MSM8916
Modem board: MSM8916
Security patch: 2016-05-01
RF cal date: 2016.08.27
IMEI:
Bypass FRP... OK
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Old 09-08-2017, 10:34   #2043 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 456
FLASH INSTRUCTIONS:
Phone must be powered off!
1. Select correct COM port in 'Port' options.
2. Choose correct flashfiles .
3. Press 'Flash' button.
4. Connect the phone to selected port with UART cable and press 'Power' button shortly
or just insert cable to phone if you are using auto-ignition cable.
(If you have connection problem, try to push 'Power' button while loader will be sent.)
Operation: Flash
Selected model: GT-E1180
Selected port: COM84 Prolific USB-to-Serial Comm Port, 460800
Connect phone, press power button
Waiting phone... OK
Sending PRELOADER... OK
Flash ID: 7A (K5N6433ATB_TOP_Boot)
Sending LOADER... OK
Checking LOADER... OK
Writing BIN... OK
Writing LPD... OK
Formatting TFS... OK
Erasing TFS... OK
Mounting TFS... OK
Sending NAND checksum... OK
Set time TFS... OK
Creating TFS directories... OK
Writing TFS VERSION... OK
Writing TFS files... OK
Unmounting TFS... OK
Formatting CSC... OK
Sending CSC checksum... OK
Set time TFS... OK
Creating CSC directories... OK
Writing CSC files... OK
Unmounting CSC... OK
Flashing done (time - 00:09:35)
Old 09-12-2017, 09:27   #2044 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 456
FLASH INSTRUCTIONS:
Operation: Flash
Selected model: SM-C101
File analysis... OK
Total file size: 0x5F6DB124 (1526 Mb)
Searching USB Flash interface... COM42 detected
Sending system.img... OK
Sending camera.bin... OK
Sending cache.img... OK
Sending hidden.img... OK
Flashing done (time - 00:07:25)
Old 09-13-2017, 14:18   #2045 (permalink)
yassinek85's Avatar
Member: 938547
Sonork: 100.1591926
Thanks Meter: 481
N930VVRS3APL2 full rom needed.
In extreme cases, one of these is suitable:
N930PVPU3APL2
N930TUVU3APL2
N930R4TYS3APL2
N930R7WWS3APL2
N9300CHC3BQB1
Old 09-13-2017, 14:18   #2046 (permalink)
yassinek85's Avatar
Member: 938547
Sonork: 100.1591926
Thanks Meter: 481
N930PVPU3APL2
N930TUVU3APL2
N930R4TYS3APL2
N930R7WWS3APL2
N9300CHC3BQB1
Old 09-13-2017, 20:15   #2047 (permalink)
Member: 2083112
Thanks Meter: 6
I need very urgent samsunga800j flash file
No file in z3x shell plz upload as soon as possible
Old 09-14-2017, 05:56   #2048 (permalink)
applestorebd's Avatar
Member: 1659078
Sonork: Mahidi Munna
Thanks Meter: 199
Thumbs up Add G955N Combination Firmware
Please Add G955N Galaxy S8+ Combination Firmware
Thanx In Advance For IT
Old 09-18-2017, 15:23   #2049 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 456
FLASH INSTRUCTIONS:
Operation: Flash
Selected model: SM-G531H/DS
Software version: 28.6
File analysis... OK
Total file size: 0x595C8170 (1429 Mb)
Searching USB Flash interface... COM17 detected
Sending spl.img... OK
Sending sboot.bin... OK
Sending sboot2.bin... OK
Sending SPRDCP.img... OK
Sending SPRDDSP.img... OK
Flashing done (time - 00:01:42)
Done with Samsung Tool PRO v.28.6
Old 09-18-2017, 19:45   #2050 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
Samsung J120A Frp Reset
Selected model: SM-J120A
Software version: 29.1
Model: SAMSUNG-SM-J120A
Product code: SM2J120AZWGATT
Phone version: J120AUCU2APJ2
PDA version: J120AUCU2APJ2
CSC version: J120AATT2APJ2
CSC sales code: ATT
HW version: REV0.3
Phone SN: R58H60BZ1NK
Chip name: EXYNOS3475
Modem board: SHANNON308
Security patch: 2016-10-01
RF cal date: 20160602
IMEI:
Bypass FRP... OK
Done with Samsung Tool PRO v.29.1
Old 09-18-2017, 19:46   #2051 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
Samsung J500H Frp Reset
Operation: Reset FRP/React/EE
Selected model: SM-J500H
Searching Samsung USB Flash interface... COM31 detected
Searching FRP lock... OK
Erasing FRP lock... OK
Reset done
Old 09-18-2017, 19:47   #2052 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
Samsung G531H Frp Reset
Searching Samsung USB Flash interface... COM10 detected
Erasing FRP... OK
Searching Reactivation lock... not supported
Searching EE lock... OK
Erasing EE lock... OK
Reset done
Old 09-18-2017, 19:47   #2053 (permalink)
Tanha0321's Avatar
Member: 314003
Thanks Meter: 2,999
Samsung S5830D Network Code Read
Operation: Read Codes
Selected model: GT-S5830D
Selected port: COM278 SAMSUNG Android USB Diagnostic Serial Port (WDM)
Checking phone at COM278
Reading phone info... OK
Model: GT-S5830D
Country code: ij³ª´Ù / TLS
Cal date: 2011-09-15
Factory SW: S5830DTLKI4_TLSKI4
Unique number: 55100001912391
Memory phone: KAT007012B(S5830)
Phone SN: RRPBA18460
PDA/CSC version: S5830DTLKI4/S5830DTLSKI4
Phone version: S5830DTLKI4
Phone HW: REV1.0
Cal date: 2011.11.02
Reading IMEI... OK
IMEI: 359079040720188
Reseting MSL... OK
Bypass MSL... OK
Reading codes... OK
Freeze code: 38530618
NET lock: 95859029
SUB lock: 00000000
SP lock: 95859029
CP lock: 00000000
For check lock status: *#7465625#
Old 09-19-2017, 07:17   #2054 (permalink)
Member: 1659078
Thanks Meter: 199
Thumbs up Please Add S8 G950N Combination
Dear Z3x Team Z3x Is World First team For Sucess Samsung Mobile Repair
Please Add G950N Combination File On Z3x Shell
Thanx Z3x Team
Old 09-19-2017, 09:16   #2055 (permalink)
Member: 773364
I need combination file for
Phone version:
PDA versione: G925FXXU5DQA7
CSC versione: G925FWIN5DQA2
COMBINATION_OXA_FA50_G925FXXU5APK6_OXA5APK6 not work
LG Flash Files Requests are here: NoName® Z3X-Team Products 540 06-14-2021 13:30
Full Flash Files, Here are some links, add more if you can simbirley Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 13 07-16-2013 08:33
Samsung A877, Flasher and flash files request??? jham Samsung Flashers, Software, Firmware. 3 05-09-2011 13:13
All member request plz post here all Huawei flash file request mohit_kripalu01 Various CDMA/TDMA Cell Phones 0 10-06-2009 14:38
Page generated in 0.26841 seconds with 10 queries
