Old 06-23-2017, 10:14   #2026 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 189
M919 flash done
FLASH INSTRUCTIONS:
1. Choose correct flash file(s).
2. If you have PIT file chosen, then you must check 'Repartition' option.
3. Check flashing options if needed (Repartition, EFS clear, Boot update).
4. Power on phone in download mode (turn off phone, press vol.down + home + power).
5. Connect phone to PC with USB cable, install drivers if needed.
6. Press 'Flash' button.
Operation: Flash
Selected model: SGH-M919
Software version: 28.2
File analysis... Ok
Total file size: 0x97414F94 (2420 Mb)
Searching USB Flash interface... COM11 detected
Setup connection... Ok
Set PIT file... Ok
Reading PIT from phone... Ok
Sending aboot.mbn... Ok
Sending sbl1.mbn... Ok
Sending sbl2.mbn... Ok
Sending sbl3.mbn... Ok
Sending rpm.mbn... Ok
Sending tz.mbn... Ok
Sending boot.img... Ok
Sending recovery.img... Ok
Sending persdata.img.ext4... Ok
Sending system.img.ext4... Ok
Sending modem.bin... Ok
Sending NON-HLOS.bin... Ok
Sending cache.img.ext4... Ok
Sending hidden.img.ext4... Ok
Flashing done (time - 00:08:11)
Done with Samsung Tool PRO v.28.2
Old 08-14-2017, 13:53   #2027 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 189
Sm-g355h flash done
SM-G355H FLASH DONE
FLASH INSTRUCTIONS:
4. Power on the phone in download mode (turn off phone, press vol.down + home + power).
5. Connect the phone to PC with USB cable, install drivers if needed.
Operation: Flash
Selected model: SM-G355H
Software version: 29.1
File analysis... OK
Total file size: 0x462CB6DC (1122 Mb)
Searching USB Flash interface... COM4 detected
Setup connection... OK
Reading PIT from phone... OK
Sending spl.img... OK
Sending sboot.bin... OK
Sending sboot2.bin... OK
Sending boot.img... OK
Sending recovery.img... OK
Sending system.img... OK
Sending SPRDCP.img... OK
Sending SPRDDSP.img... OK
Sending cache.img... OK
Sending hidden.img... OK
Flashing done (time - 00:05:24)
Done with Samsung Tool PRO v.29.1
Old 08-15-2017, 11:25   #2028 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 189
FLASH INSTRUCTIONS:
Operation: Flash
Selected model: SM-J700F/DS
File analysis... OK
Total file size: 0x290C7DA8 (656 Mb)
Sending param.bin... OK
Sending cm.bin... OK
Sending persdata.img... OK
Sending modem.bin... OK
Flashing done (time - 00:00:33)
Old 08-21-2017, 13:07   #2029 (permalink)
Member: 906256
Thanks Meter: 17
hi mr blang.plz add COMBINATION_FAC_FA60_A720FXXU2AQF8_FAC2AQF8_CL1059 0593_QB14046659_REV01_user_mid_noship.tar
Old 08-21-2017, 15:01   #2030 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 189
FLASH INSTRUCTIONS:
4. Check flashing options if needed (Repartition, EFS clear, Boot update).
5. Power on phone in download mode (turn off phone, press vol.down + home + power).
6. Connect phone to PC with USB cable, install drivers if needed.
7. Press 'Flash' button.
Operation: Flash
Selected model: SM-T230
Software version: 27.7
File analysis... Ok
Total file size: 0x5A996C50 (1449 Mb)
Searching USB Flash interface... COM6 detected
Sending spl.img... Ok
Sending sboot.bin... Ok
Sending sboot2.bin... Ok
Sending system.img... Ok
Sending SPRDCP.img... Ok
Sending SPRDDSP.img... Ok
Sending cache.img... Ok
Sending hidden.img... Ok
Flashing done (time - 00:02:04)
Done with Samsung Tool PRO v.27.7
Old 08-21-2017, 15:33   #2031 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 189
FLASH INSTRUCTIONS:
Operation: Flash
Selected model: SM-N910A
File analysis... Ok
Total file size: 0x2686B69C (616 Mb)
Sending sdi.mbn... Ok
Sending persist.img.ext4... Ok
Flashing done (time - 00:01:03)
Old 08-22-2017, 10:31   #2032 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 189
FLASH INSTRUCTIONS:
Operation: Flash
File analysis... Ok
Flashing done (time - 00:01:33)
Old 08-24-2017, 13:59   #2033 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 189
FLASH INSTRUCTIONS:
Operation: Flash
File analysis... OK
Total file size: 0xDDA603E4 (3546 Mb)
Searching USB Flash interface... COM37 detected
Set PIT file... OK
Sending aboot.mbn... OK
Sending sbl1.mbn... OK
Sending rpm.mbn... OK
Sending tz.mbn... OK
Sending sdi.mbn... OK
Sending NON-HLOS.bin... OK
Sending system.img.ext4... OK
Sending persist.img.ext4... OK
Sending cache.img.ext4... OK
Flashing done (time - 00:05:01)
Old 08-25-2017, 11:20   #2034 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 189
FLASH INSTRUCTIONS:
Operation: Flash
Selected model: SM-G925F
File analysis... OK
Total file size: 0xE3475111 (3636 Mb)
Searching USB Flash interface... COM52 detected
Set PIT file... OK
Flashing done (time - 00:04:44)
Old 08-25-2017, 13:50   #2035 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 189
FLASH INSTRUCTIONS:
Operation: Flash
Selected model: SM-A500F
File analysis... OK
Total file size: 0x8B81CF40 (2232 Mb)
Sending hyp.mbn... OK
Sending sec.dat... OK
Sending hidden.img.ext4... OK
Flashing done (time - 00:07:22)
Old 08-26-2017, 12:30   #2036 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 189
FLASH INSTRUCTIONS:
Operation: Flash
Selected model: SM-G920P
File analysis... OK
Total file size: 0xE6D53BB0 (3693 Mb)
Searching USB Flash interface... COM59 detected
Flashing done (time - 00:04:52)
Old 08-26-2017, 15:30   #2037 (permalink)
Member: 2620145
Thanks Meter: 25
pls any body help
Old 08-26-2017, 16:05   #2038 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 189
Scanning devices ... 1 found
dev[1]
Manufactory: SAMSUNG
Model:
Hardware:
Mode: DOWNLOAD
Connect to device ...
Device pit saved to E:\BST\backup\samsung\pit\SM-G920P\SM-G920P_2017-08-26_06.57.19.pit
Write file sboot.bin ...
Write file cm.bin ...
Write file boot.img ...
Write file recovery.img ...
Write file system.img ...
Write file cache.img ...
Write file modem.bin ...
Flash completed
Time used : 4 min 12 s
Old 08-30-2017, 13:41   #2039 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 189
BACKUP INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or
press 'Write CERT' to restore certificates.
To backup/restore QCN, phone diagnostic port must be enabled.
2. Type *#0808# and select 'DM+MODEM+ADB'.
3. Type *#9090# and select 'DM/DUN over HSIC'.
Or use 'Activate Diag' function from 'Repair' tab.
4. Connect the phone to PC with USB cable, install drivers if needed.
5. Select diagnostic port in port settings.
6. Press 'Read QCN' button to read NV backup or 'Write QCN' to restore.
Operation: Flash
Software version: 28.6
File analysis... OK
Total file size: 0xE620865C (3682 Mb)
Searching USB Flash interface... COM8 detected
Set PIT file... OK
Flashing done (time - 00:05:37)
Done with Samsung Tool PRO v.28.6
Old 09-06-2017, 10:21   #2040 (permalink)
orhan5's Avatar
Member: 2621892
Sonork: 1677742
Thanks Meter: 189
REPAIR INSTRUCTIONS:
5. Fill values what you need to repair.
6. Press 'Repair' button.
Operation: Patch Certificate
Selected model: SM-J320H/DS
Software version: 29.2
Waiting ADB device... OK
Reading phone info...
Model: SM-J320H
Android version: 5.1.1
Product code: SM-J320HZKDDKR
Phone version: J320HXXU0APH1
PDA version: J320HXXS0AQF2
CSC version: J320HOJV0AQC3
CSC country code: Senegal
CSC sales code: DKR
HW version: MP 0.300
Phone SN: R51J101MC5Y
Modem board: SC7730SW
Security patch: 2017-06-01
RF cal date: 20170104
IMEI:
Checking Super user right... true
Patching CERT check... OK
Rebooting phone... OK
Patching CERT check... done
Done with Samsung Tool PRO v.29.2
LG Flash Files Requests are here: NoName® Z3X-Team Products 479 Yesterday 10:48
Full Flash Files, Here are some links, add more if you can simbirley Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 13 07-16-2013 09:33
Samsung A877, Flasher and flash files request??? jham Samsung Flashers, Software, Firmware. 3 05-09-2011 14:13
All member request plz post here all Huawei flash file request mohit_kripalu01 Various CDMA/TDMA Cell Phones 0 10-06-2009 15:38
Page generated in 0.43546 seconds with 9 queries
