09-06-2017, 12:58 | #2041 (permalink) |
No Life Poster Join Date: Sep 2016 Location: IN THIS WORLD Age: 33
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G901F Software version: 29.2 File analysis... OK Total file size: 0xF925B15C (3986 Mb) Searching USB Flash interface... COM74 detected Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending aboot.mbn... OK Sending sbl1.mbn... OK Sending rpm.mbn... OK Sending tz.mbn... OK Sending sdi.mbn... OK Sending NON-HLOS.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img.ext4... OK Sending persist.img.ext4... OK Sending userdata.img.ext4... OK Sending modem.bin... OK Sending cache.img.ext4... OK Sending hidden.img.ext4... OK Flashing done (time - 00:12:53) Done with Samsung Tool PRO v.29.2 |
09-06-2017, 18:17 | #2042 (permalink) |
No Life Poster Join Date: Dec 2009 Location: ***** Taste Good Age: 39
Member: 1196914 Status: Offline Sonork: 100.1667938 Thanks Meter: 1,645 | UNLOCK INSTRUCTIONS: Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Run dialer and type *#0*# (service mode will apear). 3. Connect the phone to UART cable, choose correct COM port in port settings. 4. Press 'Unlock' button. 5. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) To reset Google account activation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP' and follow the instructions in program. 5. When process done, press 'Back' on phone and perform factory reset from phone settings. To reset Google account activation or Samsung reactivation lock: 1. Power on the phone in download mode (turn off phone, press vol.down + home + power). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Reset FRP Selected model: SM-J320VPP Software version: 29.2 Waiting ADB device... OK Reading phone info... Model: SM-J320V Android version: 6.0.1 Product code: Not Active Phone version: J320VVRU2APE1 PDA version: J320VVRU2APE1 CSC version: J320VVZW2APE1 CSC country code: USA CSC sales code: VZW HW version: J320V.03 Phone SN: R28H83ETQYD Chip name: MSM8916 Modem board: MSM8916 Security patch: 2016-05-01 RF cal date: 2016.08.27 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.2 |
09-08-2017, 10:34 | #2043 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | FLASH INSTRUCTIONS: Phone must be powered off! 1. Select correct COM port in 'Port' options. 2. Choose correct flashfiles . 3. Press 'Flash' button. 4. Connect the phone to selected port with UART cable and press 'Power' button shortly or just insert cable to phone if you are using auto-ignition cable. (If you have connection problem, try to push 'Power' button while loader will be sent.) Operation: Flash Selected model: GT-E1180 Selected port: COM84 Prolific USB-to-Serial Comm Port, 460800 Software version: 29.2 Connect phone, press power button Waiting phone... OK Sending PRELOADER... OK Flash ID: 7A (K5N6433ATB_TOP_Boot) Sending LOADER... OK Checking LOADER... OK Writing BIN... OK Writing LPD... OK Formatting TFS... OK Erasing TFS... OK Checking LOADER... OK Mounting TFS... OK Sending NAND checksum... OK Set time TFS... OK Creating TFS directories... OK Writing TFS VERSION... OK Writing TFS files... OK Unmounting TFS... OK Checking LOADER... OK Formatting CSC... OK Checking LOADER... OK Sending CSC checksum... OK Set time TFS... OK Creating CSC directories... OK Writing CSC files... OK Unmounting CSC... OK Flashing done (time - 00:09:35) Done with Samsung Tool PRO v.29.2 |
09-12-2017, 09:27 | #2044 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-C101 Software version: 29.2 File analysis... OK Total file size: 0x5F6DB124 (1526 Mb) Searching USB Flash interface... COM42 detected Setup connection... OK Reading PIT from phone... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending camera.bin... OK Sending modem.bin... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:07:25) Done with Samsung Tool PRO v.29.2 |
09-13-2017, 14:18 | #2045 (permalink) |
No Life Poster Join Date: Jan 2009 Location: SPAIN
Member: 938547 Status: Offline Sonork: 100.1591926 Thanks Meter: 481 | N930VVRS3APL2 full rom needed. In extreme cases, one of these is suitable: N930PVPU3APL2 N930TUVU3APL2 N930R4TYS3APL2 N930R7WWS3APL2 N9300CHC3BQB1 |
09-13-2017, 14:18 | #2046 (permalink) |
09-18-2017, 15:23 | #2049 (permalink) |
Member: 2621892 Status: Offline Sonork: 1677742 Thanks Meter: 456 | FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on the phone in download mode (turn off phone, press vol.down + home + power). 5. Connect the phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G531H/DS Software version: 28.6 File analysis... OK Total file size: 0x595C8170 (1429 Mb) Searching USB Flash interface... COM17 detected Setup connection... OK Reading PIT from phone... OK Sending spl.img... OK Sending sboot.bin... OK Sending sboot2.bin... OK Sending boot.img... OK Sending recovery.img... OK Sending system.img... OK Sending SPRDCP.img... OK Sending SPRDDSP.img... OK Sending cache.img... OK Sending hidden.img... OK Flashing done (time - 00:01:42) Done with Samsung Tool PRO v.28.6 |
09-18-2017, 19:45 | #2050 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,998 | Samsung J120A Frp Reset Code: Operation: Reset FRP Selected model: SM-J120A Software version: 29.1 Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-J120A Android version: 6.0.1 Product code: SM2J120AZWGATT Phone version: J120AUCU2APJ2 PDA version: J120AUCU2APJ2 CSC version: J120AATT2APJ2 CSC country code: USA CSC sales code: ATT HW version: REV0.3 Phone SN: R58H60BZ1NK Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2016-10-01 RF cal date: 20160602 IMEI: Bypass FRP... OK For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.1 |
09-18-2017, 19:46 | #2051 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,998 | Samsung J500H Frp Reset Code: Operation: Reset FRP/React/EE Selected model: SM-J500H Software version: 29.2 Searching Samsung USB Flash interface... COM31 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP lock... OK Reset done For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset' Done with Samsung Tool PRO v.29.2 |
09-18-2017, 19:47 | #2052 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,998 | Samsung G531H Frp Reset Code: Operation: Reset FRP/React/EE Selected model: SM-G531H Software version: 29.2 Searching Samsung USB Flash interface... COM10 detected Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.29.2 |
09-18-2017, 19:47 | #2053 (permalink) |
Member: 314003 Status: Offline Thanks Meter: 2,998 | Samsung S5830D Network Code Read Code: Operation: Read Codes Selected model: GT-S5830D Selected port: COM278 SAMSUNG Android USB Diagnostic Serial Port (WDM) Software version: 29.2 Checking phone at COM278 Reading phone info... OK Model: GT-S5830D Country code: ij³ª´Ù / TLS Cal date: 2011-09-15 Factory SW: S5830DTLKI4_TLSKI4 Unique number: 55100001912391 Memory phone: KAT007012B(S5830) Phone SN: RRPBA18460 PDA/CSC version: S5830DTLKI4/S5830DTLSKI4 Phone version: S5830DTLKI4 Phone HW: REV1.0 Cal date: 2011.11.02 Reading IMEI... OK IMEI: 359079040720188 Reseting MSL... OK Bypass MSL... OK Reading codes... OK Freeze code: 38530618 NET lock: 95859029 SUB lock: 00000000 SP lock: 95859029 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.29.2 |
09-19-2017, 07:17 | #2054 (permalink) |
No Life Poster Join Date: Sep 2011 Location: Dhaka,Bangldesh
Member: 1659078 Status: Offline Sonork: Mahidi Munna Thanks Meter: 199 | Please Add S8 G950N Combination Dear Z3x Team Z3x Is World First team For Sucess Samsung Mobile Repair Please Add G950N Combination File On Z3x Shell Thanx Z3x Team |
LG Flash Files Requests are here: | NoName® | Z3X-Team Products | 540 | 06-14-2021 13:30 |
Full Flash Files, Here are some links, add more if you can | simbirley | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 13 | 07-16-2013 08:33 |
Samsung A877, Flasher and flash files request??? | jham | Samsung Flashers, Software, Firmware. | 3 | 05-09-2011 13:13 |
All member request plz post here all Huawei flash file request | mohit_kripalu01 | Various CDMA/TDMA Cell Phones | 0 | 10-06-2009 14:38 |
