11-01-2015, 14:10 | #1 (permalink) |
Freak Poster Join Date: May 2004 Age: 44
Member: 66510 Status: Offline Thanks Meter: 27 | samsung g355h when flash imei 0000000 REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Fill values what you need to repair. 5. Press 'Repair' button. Operation: Repair Selected model: SM-G355H/DS Software version: 23.2 Waiting ADB device... OK Reading phone info... Model: SM-G355H Android version: 4.4.2 Product code: Unknown Phone version: G355HXXU0ANH6 PDA version: G355HXXU0ANH9 CSC version: G355HOJV0ANH9 CSC country code: UAE CSC sales code: XSG HW version: Unknown1 Phone S/N: Modem board: sc7735s RF cal date: Unknown IMEI: 000000000000000 Checking Super user right... true Bypass MSL... error (-1) Done with Samsung Tool PRO v.23.2 what is this problem ? plz clear how i repair imei. |
12-22-2015, 17:02 | #3 (permalink) | |
Freak Poster Join Date: Aug 2012 Location: jodhpur india Age: 41
Member: 1796401 Status: Offline Sonork: 100.1623409 Thanks Meter: 56 | Quote:
flash modem only and try agan | |
12-22-2015, 19:31 | #4 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: FIND SOMETHING NEW
Member: 1103669 Status: Offline Thanks Meter: 16 | Quote:
same pro any one solve this pro i have 2 handset same issue or show in rcovery mode failed to mount efs.... | |
12-22-2015, 22:12 | #5 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Left out from our gsm field Age: 29
Member: 2386560 Status: Offline Sonork: NOW I DON'T USE IT Thanks Meter: 561 | 1 St disIbal u r factory mode yellow word enter this code *: *#87976633# code not work then,u can also do with z3x disIbal factory mode option Then try to reset/repair/write efs with z3x (any one) Then rewrite imei with samsung tool ver 18.2 100% tested solution by me Don't forget to press thanks button |
The Following 2 Users Say Thank You to vickyjadhav6161 For This Useful Post: |
08-03-2017, 11:06 | #7 (permalink) |
Freak Poster Join Date: Jan 2013 Location: INDIA ANDHRAPRADESH Age: 32
Member: 1873923 Status: Offline Thanks Meter: 41 | SELECT G355HN/DS REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Fill values what you need to repair. 6. Press 'Repair' button. Operation: Repair Selected model: SM-G355HN/DS Software version: 28.1 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... Ok Reading phone info... Model: SM-G355H Android version: 4.4.2 Product code: Unknown Phone version: G355HXXU0ANH7 PDA version: G355HXXU0ANHA CSC version: G355HOLB0ANH1 CSC country code: THAILAND CSC sales code: THL HW version: Unknown1 Phone SN: Modem board: sc7735s RF cal date: Unknown IMEI: 000000000000000 Incorrect model selected. This may damage your phone. Continue? Yes Checking Super user right... true Checking MSL... Ok Initialization AT RIL... Ok Bypass MSL Ok Repairing IMEI... Ok Repairing Slave IMEI... Ok Rebooting phone... Ok Repair done Done with Samsung Tool PRO v.28.1 |
