08-11-2017, 18:35 | #1 (permalink) |
Freak Poster Join Date: May 2017 Location: NYC
Member: 2721132 Status: Offline Thanks Meter: 39 | FRP for G920v still on. Please, Help. |
08-11-2017, 20:12 | #2 (permalink) |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Bro creat a samsung account then restart the phone when it askes for account add the account you made Or Sign in on pc or other pc after you add the sam account on the phone and diactivate reactivation and do factory reset IF YOU.LIKE WHAT I POST PRESS THANKS BUTTON |
The Following User Says Thank You to souma_k For This Useful Post: |
08-11-2017, 20:16 | #3 (permalink) |
Member: 1933823 Status: Offline Thanks Meter: 1,273 | You can try to enable OEM unlocking after You remove Reactivation Lock, so that account won't be activated again after writing of a firmware. Also, make sure that You've performed all of the steps, required to remove Reactivation Lock: Instructions for Samsung Account reset: 1. Create new Samsung account (via PC or via another phone). You should have working Samsung Account. 2. Perform the "Reset FRP/ Reactivation" operation. 3. When FRP lock will be successfully reseted, wait 3-4 minutes, then go to "Backup and reset" and try to make "Factory data reset" - the phone will ask You to enter Samsung account data - enter Samsung account data, which You have created earlier. If "Factory data reset can"t be done via phone"s menu, try to make "Factory data reset" via Recovery mode ("wipe data/factory reset"). 4. Restart the phone and connect it to Wi-Fi. 5. Go to https://findmymobile.samsung.com/ and log in with the username and password (which You have created earlier). In there select the phone that it just added to account, select "Unlock my device" and "Unlock Reactivation lock". IF YOU.LIKE WHAT I POST PRESS THANKS BUTTON |
The Following 3 Users Say Thank You to souma_k For This Useful Post: |
08-11-2017, 21:17 | #4 (permalink) | |
Member: 2721132 Status: Offline Thanks Meter: 39 | Quote:
Thank you for your responses, I am going to tap the thank you button for you, And I tried the first one you posted,when I going to remove the account, it all showed processing failed, what should I do ? (I logged in with my own samsung account) | |
08-11-2017, 21:20 | #6 (permalink) |
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Bro log in from pc or other phone and remove reactivation lock and do factory reset IF YOU.LIKE WHAT I POST PRESS THANKS BUTTON |
08-11-2017, 21:44 | #10 (permalink) |
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Bro do you have uart cable? IF YOU.LIKE WHAT I POST PRESS THANKS BUTTON |
08-11-2017, 22:37 | #14 (permalink) |
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Yes bro excuse me i know that this phone is exynos phone and it should be supported then i checked it is not niether on octopus The way is to sign in to a samsung account and remove using find my phone and remove reactivation IF YOU LIKE WHAT I POST PRESS THANKS BUTTON |
08-11-2017, 22:48 | #15 (permalink) | |
thank you for the responses, I am going to try it one more time with what you posted above. | |
