10-12-2022, 12:02 | #1 (permalink) |
Freak Poster Join Date: Dec 2018 Location: Harare Zimbabwe Age: 33
Member: 2883035 Status: Offline Thanks Meter: 84 | Samsung G950f Network unlock fails [Answered] Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will appear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. To read security codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, select 'Read codes ...' algo, write your login and password in window if it will appear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server [UPLOAD 2021] Selected model: SM-G950F Software version: 44.15 Checking Login and Password... OK Balance: 24 crd. You have 24 credit(s) left. This operation takes 5 credits. Attention! In case if phone asking MCK code, using this method will consume credits twice - first for MCK code and then for NCK. Continue? Yes Waiting ADB device... OK Reading phone info... Model: SM-G950F Android version: 9 PDA version: G950FXXUCDVG4 CSC version: G950FEVRCDUC2 Phone version: G950FXXUCDUD1 Product code: SM-G950FZKAEVR CSC country code: UK CSC sales code: EVR Carrier ID: EVR Phone SN: RF8KB231FDR IMEI: 352802103292630 HW version: MP 0.700 RF cal date: 20181117 Chip name: EXYNOS8895 Modem board: SHANNON355 Security patch: 2021-04-01 Boot Warranty bit: 0 SIM State: NETWORK_LOCKED Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Initialization zTool Loader... OK Running zTool, please wait... OK Loading... OK Initialization zTool... OK Running zTool, please wait... OK Reading lock state... OK Searching Samsung modem... detected COM10 Your phone is requesting a MCK(Freeze) code. What code do you want to calculate? MCK(Freeze) Executing... OK Searching Ramdump interface... COM28 detected Rebooting phone... OK Waiting ADB device... OK Waiting for device to become ready... OK Reading ramdump data from phone... OK Calculating... error (2) Could not find data. Please try again. Done with Samsung Tool PRO v.44.15 [SM-G950F,Read Codes via Server [UPLOAD 2021]] |
