06-08-2016, 14:19 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Moldova
Member: 614304 Status: Offline Thanks Meter: 150 | Samsung G361H/DS Error to reset FRP ! Need Help ! 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)⃞⃞⃞ Operation: Reset FRP/React/EE Selected model: SM-G361H/DS Software version: 25.5 Searching Samsung USB Flash Interface... detected COM9 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... error Done with Samsung Tool PRO v.25.5 I try by free bypass method i enter in menu reset delete all data but also after phone restart need google account, i flash phone with 4 file ....any other method ? |
The Following User Says Thank You to Unlocker_001 For This Useful Post: |
06-08-2016, 14:57 | #2 (permalink) |
Insane Poster Join Date: Jan 2015
Member: 2321119 Status: Offline Thanks Meter: 119 | DONT PANIC FLASH THIS FILE IN BL THE RESET WITH BOX Dev-Host - FRP_G361H_BY_ALOSYRIA_HALABTACh.tar.md5 - The Ultimate Free File Hosting / File Sharing Service ONLY THANKS BUTTON T |
The Following 6 Users Say Thank You to tarek.mobile For This Useful Post: |
06-08-2016, 16:19 | #3 (permalink) |
Member: 614304 Status: Offline Thanks Meter: 150 | [QUOTE=tarek.mobile;11863488]DONT PANIC FLASH THIS FILE IN BL THE RESET WITH BOX Dev-Host - FRP_G361H_BY_ALOSYRIA_HALABTACh.tar.md5 - The Ultimate Free File Hosting / File Sharing Service ONLY THANKS BUTTON After flash with this file phone dead, no image on lcd only back light |
The Following 2 Users Say Thank You to Unlocker_001 For This Useful Post: |
06-08-2016, 16:29 | #4 (permalink) |
Member: 614304 Status: Offline Thanks Meter: 150 | Solution is to flash phone with older firmware from 2015 after that RESET work. Thanks to all ! |
06-09-2016, 09:49 | #5 (permalink) |
Member: 2321119 Status: Offline Thanks Meter: 119 | flashing older firmware will make the phone dead as well...this file is tested over 15peices now with no problems at all !! this is an 2015 sboot file and its easier to download and flash then downloading a whole firmware and wasting time waiting for it to be downkoaded man.. |
06-09-2016, 11:15 | #6 (permalink) | |
Product Supporter Join Date: Oct 2010 Location: DHAKA Mobile
Member: 1417131 Status: Offline Sonork: Uninstalled Thanks Meter: 1,090 | Quote:
http://forum.gsmhosting.com/vbb/f453...41/index5.html | |
09-17-2016, 08:30 | #7 (permalink) | |
No Life Poster Join Date: Jun 2007 Location: Gampaha, Srilanka
Member: 527534 Status: Offline Sonork: 100.1606510 Thanks Meter: 193 | Quote:
10-02-2016, 08:53 | #8 (permalink) | |
Freak Poster Join Date: Sep 2006 Location: algerie
Member: 344811 Status: Offline Thanks Meter: 10 | Quote:
10-02-2016, 08:57 | #9 (permalink) |
Member: 614304 Status: Offline Thanks Meter: 150 | if phone dead and no image, remove battery put again, put phone in download mode by pressing home > vol- after vol + (display is black, no image) put in computer phone will be detected and flash again with stock firmware ! |
10-16-2016, 12:03 | #11 (permalink) |
Freak Poster Join Date: Nov 2015 Location: INDIA SALASAR BALAJI
Member: 2482480 Status: Offline Thanks Meter: 112 | flash this file for frp remove in g361h.... http://dc705.4shared.com/download/Wd...0989&lgfp=3000 |
The Following 3 Users Say Thank You to SLSUTHAR For This Useful Post: |
12-04-2016, 12:24 | #14 (permalink) |
No Life Poster Join Date: Jun 2008
Member: 792254 Status: Offline Sonork: al_jadeed Thanks Meter: 171 | New_Sboot_FRP_G361H - Download - 4shared - Nasir Javed . flash this file select pda after remove with anybox tested by me |
The Following 24 Users Say Thank You to asif-rashid For This Useful Post: |
12-06-2016, 19:05 | #15 (permalink) | |
Registered User Join Date: May 2009 Location: BONOUA - Ivory Coast
Member: 1040340 Status: Offline Thanks Meter: 58 | Quote:
The Following 4 Users Say Thank You to DIDIER2009 For This Useful Post: |
