Samsung G361H/DS Error to reset FRP ! Need Help ! UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)⃞⃞⃞ Operation: Reset FRP/React/EE Selected model: SM-G361H/DS Software version: 25.5 Searching Samsung USB Flash Interface... detected COM9 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... error Done with Samsung Tool PRO v.25.5 I try by free bypass method i enter in menu reset delete all data but also after phone restart need google account, i flash phone with 4 file ....any other method ? |
DONT PANIC FLASH THIS FILE IN BL THE RESET WITH BOX Dev-Host - FRP_G361H_BY_ALOSYRIA_HALABTACh.tar.md5 - The Ultimate Free File Hosting / File Sharing Service ONLY THANKS BUTTON T |
[QUOTE=tarek.mobile;11863488]DONT PANIC FLASH THIS FILE IN BL THE RESET WITH BOX Dev-Host - FRP_G361H_BY_ALOSYRIA_HALABTACh.tar.md5 - The Ultimate Free File Hosting / File Sharing Service ONLY THANKS BUTTON After flash with this file phone dead, no image on lcd only back light |
Solution is to flash phone with older firmware from 2015 after that RESET work. Thanks to all ! |
flashing older firmware will make the phone dead as well...this file is tested over 15peices now with no problems at all !! this is an 2015 sboot file and its easier to download and flash then downloading a whole firmware and wasting time waiting for it to be downkoaded man.. |
http://forum.gsmhosting.com/vbb/f453...41/index5.html |
oups sorry............. |
flash this file for frp remove in g361h.... http://dc705.4shared.com/download/Wd...0989&lgfp=3000 |
death flash after sat death with frp remove file,show change ,, how to solve? |
If its dead boot then Z3X alone cannot repair it. Br, xerraco |
New_Sboot_FRP_G361H - Download - 4shared - Nasir Javed . flash this file select pda after remove with anybox tested by me |
