Old 06-08-2016, 15:19   #1 (permalink)
Unlocker_001's Avatar
Member: 614304
Thanks Meter: 93
Samsung G361H/DS Error to reset FRP ! Need Help !
UNLOCK INSTRUCTIONS:
1. Power on the phone.
2. Connect the phone to PC with USB cable.
3. Check Samsung modem in device manager, install drivers if needed.
4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes.
To reset Google account activation or Samsung reactivation lock:
1. Power on phone in download mode (turn off phone, press vol.down + home + power).
2. Connect phone to PC with USB cable, install drivers if needed.
3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock.
(Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.)⃞⃞⃞
Operation: Reset FRP/React/EE
Selected model: SM-G361H/DS
Software version: 25.5
Searching Samsung USB Flash Interface... detected COM9
Setup connection... OK
Reading PIT from phone... OK
Searching FRP lock... OK
Erasing FRP... OK
Searching Reactivation lock... not supported
Searching EE lock... OK
Erasing EE lock... error
Done with Samsung Tool PRO v.25.5
I try by free bypass method i enter in menu reset delete all data but also after phone restart need google account, i flash phone with 4 file ....any other method ?
The Following User Says Thank You to Unlocker_001 For This Useful Post:
Old 06-08-2016, 15:57   #2 (permalink)
Member: 2321119
Thanks Meter: 100
DONT PANIC FLASH THIS FILE IN BL THE RESET WITH BOX
Dev-Host - FRP_G361H_BY_ALOSYRIA_HALABTACh.tar.md5 - The Ultimate Free File Hosting / File Sharing Service
ONLY THANKS BUTTON
T
The Following 6 Users Say Thank You to tarek.mobile For This Useful Post:
Old 06-08-2016, 17:19   #3 (permalink)
Member: 614304
Thanks Meter: 93
[QUOTE=tarek.mobile;11863488]DONT PANIC FLASH THIS FILE IN BL THE RESET WITH BOX
ONLY THANKS BUTTON
After flash with this file phone dead, no image on lcd only back light
The Following 2 Users Say Thank You to Unlocker_001 For This Useful Post:
Old 06-08-2016, 17:29   #4 (permalink)
Member: 614304
Thanks Meter: 93
Solution is to flash phone with older firmware from 2015 after that RESET work. Thanks to all !
Old 06-09-2016, 10:49   #5 (permalink)
Member: 2321119
Thanks Meter: 100
flashing older firmware will make the phone dead as well...this file is tested over 15peices now with no problems at all !! this is an 2015 sboot file and its easier to download and flash then downloading a whole firmware and wasting time waiting for it to be downkoaded man..
Old 06-09-2016, 12:15   #6 (permalink)
farukpdm's Avatar
Member: 1417131
Sonork: 100.1625249
Thanks Meter: 652
Erasing FRP... OK
try this
Bypass any samsung Google verify account
Old 09-17-2016, 09:30   #7 (permalink)
Member: 527534
Sonork: 100.1606510
Thanks Meter: 149
Originally Posted by tarek.mobile View Post
flashing older firmware will make the phone dead as well...this file is tested over 15peices now with no problems at all !! This is an 2015 sboot file and its easier to download and flash then downloading a whole firmware and wasting time waiting for it to be downkoaded man..
confirm... Its working fine without any matter
Old 10-02-2016, 09:53   #8 (permalink)
Member: 344811
Thanks Meter: 10
ONLY THANKS BUTTON
T
phone dead any help.....................................
Old 10-02-2016, 09:57   #9 (permalink)
Member: 614304
Thanks Meter: 93
if phone dead and no image, remove battery put again, put phone in download mode by pressing home > vol- after vol + (display is black, no image) put in computer phone will be detected and flash again with stock firmware !
Old 10-04-2016, 20:26   #10 (permalink)
Member: 2472231
Thanks Meter: 3
oups sorry.............
Old 10-16-2016, 13:03   #11 (permalink)
SLSUTHAR's Avatar
Member: 2482480
Thanks Meter: 100
flash this file for frp remove in g361h....
http://dc705.4shared.com/download/Wd...0989&lgfp=3000
The Following 3 Users Say Thank You to SLSUTHAR For This Useful Post:
Old 10-16-2016, 15:39   #12 (permalink)
Member: 1703868
Thanks Meter: 3
death
flash after sat death with frp remove file,show change ,, how to solve?
Old 10-17-2016, 04:50   #13 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 1,544
If its dead boot then Z3X alone cannot repair it.
Br,
xerraco
Old 12-04-2016, 12:24   #14 (permalink)
Member: 792254
Sonork: al_jadeed
Thanks Meter: 115
New_Sboot_FRP_G361H - Download - 4shared - Nasir Javed .
flash this file select pda after remove with anybox tested by me
The Following 20 Users Say Thank You to asif-rashid For This Useful Post:
Old 12-06-2016, 19:05   #15 (permalink)
Member: 1040340
Thanks Meter: 27
Good solution, good sboot file. Thank you.
The Following 4 Users Say Thank You to DIDIER2009 For This Useful Post:
Page generated in 0.33974 seconds with 7 queries
