01-08-2017, 15:15 | #19 (permalink) | |
Freak Poster Join Date: May 2015
Member: 2399421 Status: Offline Thanks Meter: 208 | Quote:
Big like for this good report tested.... | |
The Following User Says Thank You to sfri.arash For This Useful Post: |
02-08-2017, 12:24 | #20 (permalink) |
Major Poster Join Date: Apr 2008
Member: 742687 Status: Offline Sonork: sunilbansal Thanks Meter: 21 | Originally Posted by asif-rashid View Post New_Sboot_FRP_G361H - Download - 4shared - Nasir Javed . flash this file select pda after remove with anybox done done tested Good solution, good sboot file. Thank you. |
02-08-2017, 15:43 | #21 (permalink) | |
Freak Poster Join Date: Feb 2008 Location: PAKISTAN Age: 41
Member: 696424 Status: Offline Sonork: 100.1623404 Thanks Meter: 24 | Quote:
good working ....THanks.. | |
02-23-2017, 11:02 | #22 (permalink) | |
Freak Poster Join Date: Mar 2014 Location: Sylhet Bangladesh
Member: 2145140 Status: Offline Sonork: 100.1650938 Thanks Meter: 90 | Quote:
03-12-2017, 17:48 | #25 (permalink) | |
No Life Poster Join Date: Apr 2011 Location: algerie Age: 54
Member: 1562854 Status: Offline Sonork: 1245 Thanks Meter: 259 | Quote:
04-27-2017, 09:50 | #28 (permalink) | |
Insane Poster Join Date: May 2013
Member: 1939613 Status: Offline Thanks Meter: 6 | Quote:
05-21-2017, 05:38 | #30 (permalink) |
Junior Member Join Date: May 2013 Location: dhaka
Member: 1937769 Status: Offline Thanks Meter: 8 | g361h frp lock bypass done z3x box tips 1 download sboot file write flash any box tips 2 reset frp z3x box problem solve To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. 4. After phone reboot, go to settings and perform factory reset. Operation: Reset FRP/React/EE Selected model: SM-G361H/DS Software version: 28.2 Searching Samsung USB Flash interface... COM6 detected Setup connection... Ok Reading PIT from phone... Ok Searching FRP lock... Ok Erasing FRP... Ok Searching Reactivation lock... not supported Searching EE lock... Ok Erasing EE lock... Ok Reset done Done with Samsung Tool PRO v.28.2 |
The Following User Says Thank You to poranpakhi For This Useful Post: |
