03-25-2015, 18:09 | #1 (permalink) |
Freak Poster Join Date: May 2009
Member: 1026469 Status: Offline Thanks Meter: 65 | Samsung G386T1 MetroPCS UNLOCK DONE w/ Z3X. Samsung Tool 19.1. Steps. 1.- Select model G7102. 2.- Click Direct Unlock. Wait until phone boots. 3.- Select model G386W. 4.- Wipe EFS. Wait until phone boots. 5.- Write Cert provided here : SM-G386 cert - Download - 4shared 6.- Wait a a few minutes. Done! Note: Phone may take a couple of minutes to pick up signal, so be patient. Give thanks. Last edited by ericjose; 03-25-2015 at 18:15. |
The Following 13 Users Say Thank You to ericjose For This Useful Post: |
04-03-2015, 20:36 | #4 (permalink) |
Member: 1026469 Status: Offline Thanks Meter: 65 | I m not sure. However, if you look at other forums, you may be a able to see a post that says that it is possible but you'll have to flash your phone with the metro firmware. I'm not sure if it will work or not. Therefore, I can not guarantee this will work or that will not damage your phone . DO IT AT YOUR OWN RISK. |
04-09-2015, 20:04 | #6 (permalink) |
Junior Member Join Date: Jun 2014
Member: 2202154 Status: Offline Thanks Meter: 1 | I did the process and it works fine -- except -- now i can't get the device to work on t mobile based services ie univision tmobile gosmart , but it works fine on AT&T. It is almost acting like the imei is blacklisted but its not per swappa and checkesn. Any ideas on how to fix this issue ? |
06-25-2015, 01:06 | #7 (permalink) |
Junior Member Join Date: Oct 2014
Member: 2275453 Status: Offline Thanks Meter: 0 | When I click on write Cert. I Also get the same error: model: SM-G386W Selected port: COM29 Z3X BOX Serial Port Selected port speed: 115200 Checking certificate file... error Incorrect Public key Done with Samsung Tool v.18.9 Any ideas as how to fix this, do you think it may be the Samsung tool version I'm using? |
06-29-2015, 22:36 | #8 (permalink) |
Freak Poster Join Date: Jan 2008
Member: 693516 Status: Offline Thanks Meter: 3 | Selected model: SM-G7102 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G386T Android version: 4.4.2 Product code: SM2G386TRKATMB Phone version: G386TUVU1ANK3 PDA version: G386TUVU1ANK3 CSC version: G386TTMB1ANK3 IMEI: 358764060604021 Phone S/N: R28G517SYMK Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM3 No answer from phone Done with Samsung Tool v.19.1 Selected model: SM-G386F Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SM-G386T Android version: 4.4.2 Product code: SM2G386TRKATMB Phone version: G386TUVU1ANK3 PDA version: G386TUVU1ANK3 CSC version: G386TTMB1ANK3 IMEI: 358764060604021 Phone S/N: R28G517SYMK Checking Super user right... true Running zTool, please wait... error (2) Done with Samsung Tool v.19.1 Selected model: SM-G386U Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SM-G386T Android version: 4.4.2 Product code: SM2G386TRKATMB Phone version: G386TUVU1ANK3 PDA version: G386TUVU1ANK3 CSC version: G386TTMB1ANK3 IMEI: 358764060604021 Phone S/N: R28G517SYMK Checking Super user right... true Running zTool, please wait... error (2) Done with Samsung Tool v.19.1 Selected model: SM-G7102 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SM-G386T Android version: 4.4.2 Product code: SM2G386TRKATMB Phone version: G386TUVU1ANK3 PDA version: G386TUVU1ANK3 CSC version: G386TTMB1ANK3 IMEI: 358764060604021 Phone S/N: R28G517SYMK Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM3 No answer from phone Done with Samsung Tool v.19.1 Selected model: SM-G7102 Selected port: COM12 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SM-G386T Android version: 4.4.2 Product code: SM2G386TRKATMB Phone version: G386TUVU1ANK3 PDA version: G386TUVU1ANK3 CSC version: G386TTMB1ANK3 IMEI: 35876406 Phone S/N: R28G517SYMK Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM12 Detected ID: 00000FFB (MSM8926) SW Version: MPSS.DI.2.0.c8-00076-M8926DAAAANAZM-1 Reading ESN... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Writing data to phone... OK Rebooting phone... OK Waiting phone... OK Reading phone info... Model: SM-G386T Android version: 4.4.2 Product code: Not Active Phone version: G386TUVU1ANK3 PDA version: G386TUVU1ANK3 CSC version: G386TTMB1ANK3 IMEI: Unknown Phone S/N: R28G517SYMK Bypass MSL... OK Unlocking... OK Reading QCN file... OK Checking phone at COM12 Detected ID: 00000FFB (MSM8926) SW Version: MPSS.DI.2.0.c8-00076-M8926DAAAANAZM-1 Checking paths... OK Restoring EFS Backup... OK Restoring NV Items... OK Restoring NV Item SIM1... OK Restoring NV Item SIM2... OK Restoring Provisioning Item Files... OK Reseting... OK Unlock done Done with Samsung Tool v.19.1 Selected model: SM-G7102 Selected port: COM12 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SM-G386T1 Android version: 4.4.2 Product code: Not Active Phone version: G386T1UVU1ANH3 PDA version: G386T1UVU1ANH3 CSC version: G386T1TMB1ANH3 IMEI: 358764060604021 Phone S/N: R28G517SYMK Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM12 Detected ID: 00000FFB (MSM8926) SW Version: MPSS.DI.2.0.c8-00073-M8926DAAAANAZM-1 Reading ESN... OK Backuping RFNV... OK Backuping Feature Mask... OK Backuping NV Item... OK Backuping NV Item SIM1... OK Backuping NV Item SIM2... OK Backuping Provisioning Item Files... OK Writing data to phone... OK Rebooting phone... OK Waiting phone... OK Reading phone info... Model: SM-G386T1 Android version: 4.4.2 Product code: Not Active Phone version: G386T1UVU1ANH3 PDA version: G386T1UVU1ANH3 CSC version: Unknown IMEI: Unknown Phone S/N: R28G517SYMK Bypass MSL... OK Unlocking... OK Reading QCN file... OK Checking phone at COM12 Detected ID: 00000FFB (MSM8926) SW Version: MPSS.DI.2.0.c8-00073-M8926DAAAANAZM-1 Checking paths... OK Restoring EFS Backup... OK Restoring NV Items... OK Restoring NV Item SIM1... OK Restoring NV Item SIM2... OK Restoring Provisioning Item Files... OK Reseting... OK Unlock done Done with Samsung Tool v.19.1 |
08-27-2015, 11:43 | #9 (permalink) | |
No Life Poster Join Date: Jul 2013 Location: kpk Pakistan
Member: 1985156 Status: Offline Sonork: 100.1652265 Thanks Meter: 313 | Quote:
this solution 100 working i m use octopus box my z3x box not activated but this solution 100 working how to use samsung tool 19.1 working octopus box not support this model cert write z3x is best thin octopus | |
The Following User Says Thank You to inamullah790000 For This Useful Post: |
09-21-2016, 07:33 | #11 (permalink) | |
No Life Poster Join Date: Nov 2005 Location: Sindhu Desh Age: 36
Member: 199814 Status: Offline Thanks Meter: 1,960 | Quote:
10-05-2016, 08:54 | #12 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1411060 Status: Offline Thanks Meter: 0 | Not yet supported for z3x unlocking... So i tried this...insert unsupported simcard...turn on wifi... click DEVICE Unlock icon...select permanently unlock device...restart... BOOM! its unlocked |
12-30-2017, 19:16 | #13 (permalink) |
Junior Member Join Date: May 2015
Member: 2398307 Status: Offline Thanks Meter: 0 | MPCS Firmware for Samsung SM-G386T got a T-Mobile USA with the unlock app want to change the firmware to metro pcs so i can see the unlock sign cause its not showing right know |
10-03-2018, 15:30 | #15 (permalink) |
No Life Poster Join Date: Jan 2006 Location: Santiago de Cuba Age: 46
Member: 220595 Status: Offline Thanks Meter: 355 | anyone can post the samtung tool v19 elsewhere? it looks like it is the unique version which can write cert to g386t1, I have tried other versions, like latest or 18.9 and all five pub key error. I just need to write a cert to this phone. any idea? |
