04-23-2016, 07:28 | #1 (permalink) |
Freak Poster Join Date: Sep 2007 Location: India
Member: 583492 Status: Offline Thanks Meter: 125 | SM-G531f frp [done] after flashing UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. If phone ask codes after unlocking, use: PUK - 12345678 PIN - 00000000 To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G531F Software version: 25.2 Searching Samsung USB Flash Interface... detected COM175 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... not supported Searching EE lock... OK Erasing EE lock... OK Reset done Done with Samsung Tool PRO v.25.2 |
The Following 2 Users Say Thank You to afhaan For This Useful Post: |
04-23-2016, 08:23 | #2 (permalink) | |
Freak Poster Join Date: Jun 2013
Member: 1959450 Status: Offline Thanks Meter: 35 | Quote:
Sent from my SM-G928P using Tapatalk | |
04-23-2016, 13:44 | #3 (permalink) |
Member: 583492 Status: Offline Thanks Meter: 125 | |
01-21-2017, 13:05 | #5 (permalink) |
No Life Poster Join Date: Jan 2014 Location: gsmforum
Member: 2118052 Status: Offline Thanks Meter: 568 | frp done but I was trying to flash through this formware but.. sboot.img and system.img not flash ing giving error... So i remove both files... and flashed flashing done .. frp remove done... but mobile hang on boot logo... So i suggest to other user only flash cp/modem file... to remove frp.... |
The Following User Says Thank You to miftahulbari For This Useful Post: |
07-04-2017, 06:45 | #7 (permalink) |
Freak Poster Join Date: Nov 2009 Location: ranchi , jharkhand , india
Member: 1170863 Status: Offline Sonork: [email protected] Thanks Meter: 96 | samsung g531f frp unlock with bst https://www.4shared.com/rar/LDcuKBlT...lock_with.html |
The Following 2 Users Say Thank You to utkarshema For This Useful Post: |
