09-05-2015, 09:22 | #2 (permalink) |
Insane Poster Join Date: Aug 2004 Age: 49
Member: 77549 Status: Offline Sonork: 100.89357 Thanks Meter: 11 | g531h unlock done with z3x UNLOCK INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: SM-G531H Software version: 22.4 Searching Samsung modem... detected COM580 Reading phone info... OK Model: SM-G531H Version: G531HXXU0AOG1/G531HOJV0AOG1/G531HXXU0AOF8/G531HXXU0AOG1 Product code: SM-G531HZDDKSA Phone S/N: R51G71Q2LWJ Imei: 35295 Unique number: C5K1360CE79BA62 Reading codes... OK Please wait, calculating codes... OK (time - 00:01:45) Freeze code: 31525035 NET lock: 73704974 For check lock status: *#7465625# Done with Samsung Tool PRO v.22.4 |
09-08-2015, 04:00 | #3 (permalink) |
Freak Poster Join Date: Aug 2010 Location: Nepal
Member: 1370803 Status: Offline Sonork: ma341032 Thanks Meter: 36 | UNLOCK INSTRUCTIONS: No Need To Root Your Device. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. Operation: Read Codes Selected model: SM-G531H Software version: 22.4 Searching Samsung modem... detected COM104 Reading phone info... OK Model: SM-G531H Version: G531HXXU0AOF9/G531HOLB0AOF3/G531HDXU0AOF2/G531HXXU0AOF9 Product code: SM-G531HZWDXME Phone S/N: R51G8****** Imei: 35046********** Unique number: C5K1394F5ED8872 Reading codes... OK Please wait, calculating codes... OK (time - 00:02:25) Freeze code: 75746805 NET lock: 46270260 For check lock status: *#7465625# |
