Old 01-21-2017, 15:56   #1 (permalink)
Member: 2298369
Thanks Meter: 440
samsung g570f frp remove sucessfully
samsung g570f frp remove sucessfully-
Operation: Reset FRP
Selected model: SM-G570F
Software version: 27.7
Waiting ADB device... Ok
Reading phone info...
Model: SM-G570F
Android version: 6.0.1
Product code: SM-G570FZKDINS
Phone version: G570FXXU1API9
PDA version: FA60_G570FXXU1APJ2
CSC version:
CSC country code:
CSC sales code:
HW version: MP 0.500
Phone SN: RZ8HB018BQZ
Chip name: EXYNOS7570
Modem board: SHANNON305
RF cal date: 20161103
IMEI:
Bypass FRP... Ok
For complete reset FRP, goto 'Backup and reset' and make 'Factory data reset'
Done with Samsung Tool PRO v.27.7
The Following 2 Users Say Thank You to galaxycompue For This Useful Post:
Old 02-02-2017, 12:50   #2 (permalink)
.:MESSAD_RA:.'s Avatar
Member: 261468
Sonork: 100.1603116
Thanks Meter: 65
how do you do it bro.. thanks...
The Following User Says Thank You to .:MESSAD_RA:. For This Useful Post:
Old 02-02-2017, 14:06   #3 (permalink)
simcityreal's Avatar
Member: 955971
Sonork: 100.1638835
Thanks Meter: 115
Pls Share Full Procedure.....
The Following User Says Thank You to simcityreal For This Useful Post:
Old 02-04-2017, 07:36   #4 (permalink)
Akshayhackman's Avatar
Member: 2524325
Sonork: 100.1671897
Thanks Meter: 179
how to enable adb mode
The Following User Says Thank You to Akshayhackman For This Useful Post:
Old 03-09-2017, 07:37   #5 (permalink)
Member: 2220340
Thanks Meter: 4
flash using combination file iz z3x pro and check only boot img and sboot bin
The Following 3 Users Say Thank You to denzel80 For This Useful Post:
Old 03-10-2017, 19:10   #6 (permalink)
Member: 1600951
Sonork: 9332601051
Thanks Meter: 16
sm- g570f COMBINATION_OJV_FA60_G570FXXU1APJ2_OJV1APJ2... please click thanks botton..
https://www.4shared.com/zip/amUOaQCG...ON_OJV_FA.html
The Following 11 Users Say Thank You to souravspiderman For This Useful Post:
Old 07-13-2017, 19:49   #7 (permalink)
Member: 1713296
Thanks Meter: 67
anyone test this over 6.0.1?
The Following User Says Thank You to NsNobel2 For This Useful Post:
Old 07-14-2017, 04:39   #8 (permalink)
farukpdm's Avatar
Member: 1417131
Sonork: Uninstalled
Thanks Meter: 1,090
Model: SM-G570F
CSC version:
CSC country code:
CSC sales code:
IMEI:
Bypass FRP... Ok
I don't know how can make
but I was try with combination file not work
z3x show frp remove done
but phone have stiil locked
but when try with only sboot or cach
asking password
Sent from my SM-A310F using Tapatalk
The Following 3 Users Say Thank You to farukpdm For This Useful Post:
Old 05-24-2018, 07:52   #9 (permalink)
Member: 1159475
Sonork: multan
Thanks Meter: 68
Samsung G570F 6.0.1 FRP Unlock File
Samsung Galaxy SM G570F Sboot File For Remove FRP|Bypass Samsung FRP
Old 05-24-2018, 13:40   #10 (permalink)
Pragyan_Gehlot's Avatar
Member: 503334
Sonork: 100.1590885
Thanks Meter: 173
New Method Patch level 1 May 2018
https://www.youtube.com/watch?v=nZh9atCgQ0I
The Following 2 Users Say Thank You to Pragyan_Gehlot For This Useful Post:
Old 05-27-2018, 11:19   #11 (permalink)
Member: 1000479
Sonork: 100.1638119
Thanks Meter: 52
100% working solution for latest patch
Old 06-15-2018, 10:11   #12 (permalink)
Crazy Poster
Member: 2709364
Thanks Meter: 6
the phone ask for password after install this
Old 07-13-2018, 04:35   #13 (permalink)
Member: 1159475
Sonork: multan
Thanks Meter: 68
Samsung G570F Sboot File For FRP Must Hard Reset After Flash File
https://www.kingsfirmware.com/samsun...s-samsung-frp/
Old 07-25-2018, 08:27   #14 (permalink)
Member: 2193024
Sonork: hm josim
UNLOCK INSTRUCTIONS:
Phone must be rooted!
If the software can't root the phone automatically,
then you must root your device manually.
1. Power on the phone.
2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options',
go to 'Settings'-'Developer options' and enable 'USB debugging'.
3. Connect the phone to PC with USB cable, install drivers if needed.
4. Select device in ADB settings.
5. Press 'Unlock' button and select 'New Unlock' for direct unlock.
Reading codes using sever:
Warning! Knox warranty must be active (0x00)!
If you have it voided (0x01(void)), then you can't unlock this phone using sever.
2. Type *#0808# and select 'DM+MODEM+ADB'.
4. Press 'Read Codes via server' button, write your login and password in window if it will appear.
(Login and password will be saved as default after first input and can be changed in settings)
To reset Google account activation lock:
1. ADB must be activated in any way (you can flash sBoot from combination firmware,
make sure, that you are not upgrade sBoot).
2. Connect the phone to PC with USB cable, install drivers if needed.
3. Select device in ADB settings.
4. Press 'Reset FRP' and follow the instructions in program.
5. When process done, press 'Back' on phone and perform factory reset from phone settings.
Software version: 33.2
You must activate ADB before reset FRP Yes
Goto 'Terms and conditions' press 'NEXT' and 'AGREE' EULA Yes
Waiting ADB device... OK
Model:
Android version:
PDA version:
CSC version:
Phone version:
Product code:
CSC country code:
CSC sales code:
Phone SN:
IMEI:
HW version:
RF cal date:
Chip name:
Modem board:
Incorrect model selected. This may damage your phone. Continue? Yes
Bypass FRP... OK
Done with Samsung Tool PRO v.33.2
Old 04-08-2019, 17:28   #15 (permalink)
Member: 411207
Thanks Meter: 164
not working phone still logo
Page generated in 0.23238 seconds with 9 queries
