08-31-2017, 14:11 | #1 (permalink) |
No Life Poster Join Date: Jun 2013 Location: BANGLADESH+UAE Age: 34
Member: 1969978 Status: Offline Sonork: 100.1613242 Thanks Meter: 693 | Samsung G570f Imei 000000000000000/01 Operation: Info Selected model: SM-G570F Software version: 29.2 Searching Samsung modem... detected COM17 Reading phone info... OK Model: SM-G570F AP version: G570FXXU1APJ6 CSC version: G570FOXE1APK2 CP version: G570FXXU1APJ6 Product code: XXXXXXXXXXXXXX Phone SN: R58J40RVGTR Unique number: CQ3009190615924 Reading IMEI... OK IMEI: 000000000000000 (SIGN: NG_NONE) IMEI 2: 000000000000000 (SIGN: NG_NONE) Done with Samsung Tool PRO v.29.2 |
08-31-2017, 14:17 | #2 (permalink) | |
Freak Poster Join Date: Apr 2015 Location: pakistan
Member: 2383595 Status: Offline Sonork: 100.1681107 Thanks Meter: 10 | Quote:
Sent from my SM-G930F using Tapatalk | |
08-31-2017, 15:41 | #3 (permalink) |
Freak Poster Join Date: Jun 2016 Location: Home Age: 27
Member: 2583091 Status: Offline Thanks Meter: 413 | Dude Don't flash a combination it is useless I've tried a bunch of solutions like EFS,NV DATA and cert and combination also repair firmware but no solution because z3x keep saying ''Security Damaged'', so there is no solid solution so far! |
09-01-2017, 08:52 | #4 (permalink) | |
Member: 2368 Status: Offline Sonork: 100.111111 Thanks Meter: 186,557 | Quote:
05-28-2018, 11:02 | #6 (permalink) |
No Life Poster Join Date: Oct 2017
Member: 2766801 Status: Offline Thanks Meter: 182 | Have manage to downgrade my modem, but i m getting this ERRO'R BACKUP INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore or press 'Write CERT' to restore certificates. Read certificate operation: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't use this function. 1. Power on the phone. 2. Type *#0808# and select 'DM+MODEM+ADB'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Operation: Write CERT Selected model: SM-G570F Software version: 31.5 Waiting ADB device... OK Reading phone info... Model: SM-G570F Android version: 6.0.1 PDA version: G570FXXU1APJ6 CSC version: G570FOXE1APK2 Phone version: G570FXXU1APJ3 Product code: CSC country code: Central Asia CSC sales code: CAC Phone SN: 00000000000 IMEI: 000000000000000 HW version: RF cal date: Chip name: EXYNOS7570 Modem board: SHANNON305 Security patch: 2016-11-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Modem board: SHANNON305 HWID: A0 59 AD F1 24 C6 2A 3A 65 CC 5A FB 0A 00 00 00 Calculating... error Security damaged (hmac mismatch) Done with Samsung Tool PRO v.31.5 Whats the meaning of that erro'r? How do i solve it? |
05-28-2018, 11:02 | #7 (permalink) |
07-07-2018, 17:48 | #8 (permalink) |
Freak Poster Join Date: Feb 2012
Member: 1725010 Status: Offline Thanks Meter: 12 | @ sir blang http://forum.gsmhosting.com/vbb/f922...08/index2.html THEY MADE IT.. WRITE CERT G570F... I HOPE UR GREAT BOX TOO.. |
