11-29-2017, 13:40 | #1 (permalink) |
No Life Poster Join Date: May 2007 Location: india punjab
Member: 507832 Status: Offline Thanks Meter: 78 | samsung g570f imei 0000000001 pz solution W version: Phone SN: R28J63H26LY Chip name: EXYNOS7570 Modem board: SHANNON305 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.5 |
11-30-2017, 13:27 | #3 (permalink) | |
Product Supporter Join Date: Aug 2016
Member: 2613252 Status: Offline Thanks Meter: 1,837 | Quote:
Hi, the problem is that you can not write a certificate with IMEI code other than the original but you have to write the certificate with the original IMEI if you have the backup of the certificate and the original IMEI code and try to write it if you want it to work on the network , having the SM-G750f model the CPID certificate attached to HIWD, for the moment the certified patch is not yet supported for this model, you should try to use file combination compatible with the firmware that installed the phone and make the flash of 4-part firmware to see if the original IMEI code returns correct, or find in file nv data for the g570f model to repair the damaged security | |
The Following 2 Users Say Thank You to amleto90 For This Useful Post: |
