10-12-2016, 13:26 | #1 (permalink) |
No Life Poster Join Date: May 2010 Location: Incredible-India
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | Samsung g600fy frp prblem SET ON ON ONLY VIBRATE AND GOONLY DOWNLOAD MODE WHTS PROBLEM FILE CODE-COMBINATION_ODD_FA51_G600FYXXU1AOJ2 FLASH LOG Code: File analysis... OK Total file size: 0x00008710 (0 Mb) Searching USB Flash interface... COM95 detected Setup connection... OK Reading PIT from phone... OK Sending md5.img... OK Flashing done (time - 00:00:05) Done with Samsung Tool PRO v.26.9 |
10-14-2016, 10:50 | #5 (permalink) |
Member: 1301233 Status: Offline Sonork: Closed Thanks Meter: 9,297 | need flash with same ver.(as your combination firmware ver.) then flash with combination flash file then remove frp by z3x after flash again now frp removed and working fine |
The Following User Says Thank You to Deepesh Sharma For This Useful Post: |
