12-21-2016, 14:51 | #1 (permalink) |
No Life Poster Join Date: Nov 2014 Location: Lucknow
Member: 2298369 Status: Offline Thanks Meter: 440 | samsung g610f unlock sucessfully UNLOCK INSTRUCTIONS: To unlock: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' for direct unlock. To read security codes: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-G610F Software version: 27.5 Searching Samsung modem... detected COM5 Reading phone info... Ok Model: SM-G610F AP version: G610FDDU1APJ6 CSC version: G610FOJV1APJ2 CP version: G610FDDU1API9 Product code: SM-G610FZDDKSA Phone SN: R28HA3BQ1RM Unique number: CAJ03725DECC3A3 Reading IMEI... Ok IMEI: 353111083271872 (SIGN: OK) IMEI 2: 353112083271870 (SIGN: OK) Checking hash file... Ok Reading data from phone... Ok Modem board: SHANNON315 HWID: 95 03 00 00 00 00 00 00 00 00 00 00 C6 FC 28 16 Reading NV data... Ok Checking NV data... Ok Calculating... Ok Please wait, calculating codes... OK (time - 00:00:04) Freeze code: 37179025 NET lock: 26837258 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.27.5 |
