11-25-2013, 18:00 | #1 (permalink) | |
No Life Poster Join Date: Sep 2006 Location: EARTH
Member: 359939 Status: Offline Sonork: none Thanks Meter: 61 | Samsung G730a no network after unlock Quote:
07-31-2014, 21:01 | #11 (permalink) |
Freak Poster Join Date: Apr 2006 Location: harare zimbabwe
Member: 255977 Status: Offline Thanks Meter: 24 | Please support fix this It seems a lot of people are complaing about no signal after unlock on g730a but support is silent on the issue please help mr blang have three phones with the same issue |
05-30-2015, 17:31 | #12 (permalink) |
Junior Member Join Date: Jan 2005
Member: 103824 Status: Offline Thanks Meter: 1 | i FIX THIS PROBLEM with this process when you do the unlock don't select skip backup/restore NVM because when the unlock is done you dont have service, in the same time you do is select the bottom write QCN and select the file SM-G730A_M8930B..... this file fix the problem in the not network, this file is the backup about the cellphone. for root the cellphone i uses VRoot_1.7.0.3882_Setup.exe this works for mi |
