01-14-2017, 16:01 | #1 (permalink) |
Insane Poster Join Date: Oct 2009
Member: 1141103 Status: Offline Thanks Meter: 8 | Samsung G920i Checking NV data... error Security damaged (1) Need Help Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read EFS' button to read backup or 'Write EFS' to restore. 6. Press 'Write CERT' to restore certificates. 7. Press 'Write NV DATA' if you need to restore NV backup. Read certificate operation: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read CERT' button to read certificates. Operation: Write CERT Selected model: SM-G920I Software version: 27.7 Waiting ADB device... Ok Reading phone info... Model: SM-G920I Android version: 5.1.1 Product code: Phone version: G920IDVU3DOJ6 PDA version: G920IDVU3DOJ6 CSC version: G920IKSA3DOJ1 CSC country code: KSA CSC sales code: KSA HW version: Phone SN: 00000000000 Chip name: EXYNOS7420 Modem board: SHANNON333 RF cal date: IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... error Security damaged (1) Done with Samsung Tool PRO v.27.7 |
