03-24-2016, 01:09 | #1 (permalink) |
Freak Poster Join Date: Oct 2010 Location: Accra-Ghana
Member: 1412214 Status: Offline Thanks Meter: 6 | samsung g925t error in flashing FLASH INSTRUCTIONS: 1. Choose correct flash file(s). 2. If you have PIT file chosen, then you must check 'Repartition' option. 3. Check flashing options if needed (Repartition, EFS clear, Boot update). 4. Power on phone in download mode (turn off phone, press vol.down + home + power). 5. Connect phone to PC with USB cable, install drivers if needed. 6. Press 'Flash' button. Operation: Flash Selected model: SM-G925T Software version: 24.9 Unpacking file... ok File analysis... OK Total file size: 0xDB8E0B40 (3512 Mb) Searching USB Flash Interface... detected COM56 Setup connection... OK Set PIT file... OK Reading PIT from phone... OK Sending boot.img... error timeout Done with Samsung Tool PRO v.24.9 PLS HELP |
03-24-2016, 03:21 | #2 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
