11-15-2016, 09:47 | #1 (permalink) |
Freak Poster Join Date: Sep 2015
Member: 2453225 Status: Offline Sonork: l Thanks Meter: 31 | samsung g930f unlock error!! 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-G930F Software version: 27.1 Searching Samsung modem... detected COM28 Reading phone info... ok Model: SM-G930F AP version: G930FXXU1BPJ6 CSC version: G930FTMH1BPG7 CP version: G930FXXU1BPHK Product code: SM2G930FZDATMH Phone SN: R58H84LABQF Unique number: AD0716030896D73A48 Reading IMEI... ok IMEI: 35 (SIGN: OK) Reading data from phone... error (0) Try downgrade modem if possible Done with Samsung Tool PRO v.27.1 |
11-15-2016, 09:50 | #2 (permalink) | |
Registered User Join Date: Dec 2015 Location: Chittagong, Bangladesh
Member: 2506300 Status: Offline Thanks Meter: 345 | Quote:
The Following User Says Thank You to kamrolhasan For This Useful Post: |
11-15-2016, 10:04 | #8 (permalink) |
Member: 2506300 Status: Offline Thanks Meter: 345 | Flash This Modem Using CP/Modem parthttp://www.mediafire.com/file/emy744...UNLOCK.tar.md5 Then Unlock...... |
The Following 2 Users Say Thank You to kamrolhasan For This Useful Post: |
11-15-2016, 10:23 | #12 (permalink) | |
Member: 2453225 Status: Offline Sonork: l Thanks Meter: 31 | Quote:
unlock thx................ | |
06-03-2018, 00:47 | #14 (permalink) |
Junior Member Join Date: May 2018
Member: 2835766 Status: Offline Thanks Meter: 0 | Didn't work for me... Operation: Repair Selected model: SM-G930F Software version: 32.4 If you are looking for 'Repair Network' function then you should use 'Patch Certificate' Waiting ADB device... OK Reading phone info... Model: SM-G930F Android version: 7.0 PDA version: G930FXXS2DRBE CSC version: G930FXSA2DRAC Phone version: Product code: CSC country code: Australia CSC sales code: XSA Phone SN: R58H914RW8F IMEI: HW version: RF cal date: Chip name: EXYNOS8890 Modem board: Security patch: 2018-02-01 Boot Warranty bit: 1 Checking Super user right... true Reading NV data... OK Checking NV data... OK Can not detected modem type Done with Samsung Tool PRO v.32.4 It does that error for any modem... I have no Baseband or IMEI. Patch Certificate put the serial number back though. Anyone got any ideas?? |
06-03-2018, 01:32 | #15 (permalink) | |
Product Supporter Join Date: May 2013 Location: IN THIS WORLD ,LB,RO,
Member: 1933823 Status: Offline Thanks Meter: 1,273 | Quote:
IF THIS POST WAS HELPFUL PRESS BUTTON | |
