12-07-2017, 12:36 | #1 (permalink) |
No Life Poster Join Date: Nov 2007 Location: Kotla arab ali khan Age: 56
Member: 623703 Status: Offline Sonork: 100.1614330 Thanks Meter: 439 | >>> samsung g950w via code byZ3X Done<<< Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G950W Selected port: COM530 SAMSUNG Mobile USB Serial Port Software version: 30.1 Checking Login and Password... OK Ballance: 40 crd. You have 40 credit(s) left. This opreratin takes 5 credits.Continue? Yes Waiting ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SM-G950W Android version: 7.0 Product code: SM-G950WZVARWC Phone version: G950WVLU1AQD9 PDA version: G950WVLU1AQD9 CSC version: G950WOYA1AQD9 CSC country code: Canada CSC sales code: RWC HW version: REV1.0 Phone SN: R28J445848L Chip name: MSM8998 Modem board: MSM8998 Security patch: 2017-04-01 RF cal date: 2017.05.02 IMEI: 355757081683381 Rebooting phone... OK Waiting ADB device... Please, allow USB debugging on phone... OK Rebooting phone... OK Waiting ADB device... Please, allow USB debugging on phone... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data from phone... OK Searching Ramdump interface... COM206 detected Reading data from phone... OK Calculating... OK Searching server... OK Waiting for server answer... OK Freeze code: 62915397 NET lock: 42938649 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.30.1 |
