08-24-2017, 16:52 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | samsung g955u atyt unlock done Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Read Codes via Server Selected model: SM-G955U Software version: 29.1 Checking Login and Password... Listo Ballance: 40 crd. Waiting ADB device... Listo Leyendo información del teléfono ... Modelo: SM-G955U Android version: 7.0 Código del Producto: SM-G955UZSAATT Versión del telefono: G955USQU1AQEF PDA version: G955USQU1AQEF CSC version: G955UOYN1AQEF Código de país CSC: USA Código de Venta CSC: ATT HW version: REV1.0 Phone SN: R38J60F1DHD Chip name: MSM8998 Módem: MSM8998 Security patch: 2017-05-01 RF cal date: 2017.06.23 IMEI: Reiniciando teléfono ... Listo Waiting ADB device... Listo Reiniciando teléfono ... Listo Waiting ADB device... Listo Initialization zTool... Listo Running zTool, please wait... Start... Listo Initialization... Listo Generate and check client proof... Listo Verify proof by client... Listo Lectura de datos desde el teléfono ... Listo Searching Ramdump interface... COM33 detected Lectura de datos desde el teléfono ... Listo Calculando... Listo Buscando servidor... Listo Waiting for server answer... Listo Congelar código: 71583791 NET lock: 94292406 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 Para comprobar bloquea el estado: *#7465625# Done with Samsung Tool PRO v.29.1 |
08-29-2017, 20:28 | #2 (permalink) |
No Life Poster Join Date: Aug 2008 Location: brazil Age: 47
Member: 846805 Status: Offline Sonork: alex cavalcante Thanks Meter: 261 | Can friends help me? I have a g955u for unlocking I made the purchase of the msl code via z3x pro server, but the phone does not ask for the network unlock pin code of the message invalid chip inserted this chip not supported how can I do to unblock via z3x or some method that Open the field to insert the code ... I would be grateful .. |
