Old 06-10-2018, 15:06   #1 (permalink)
Member: 3691
Thanks Meter: 6
Samsung G955U from sprint USA [Solved]
after inserting the combination file G955USKU4ARE1 on samsung g955u for unlock the sim more can not install any firmware in the phone. The phone is in the factory binary mode and works on all SIM cards but can not install any firmware. Is there any solution for this issue.Does it have some U4 firmware so I can install it in the phone or some other solution.
Thanks,
Old 06-10-2018, 16:24   #2 (permalink)
Member: 1798634
/sub
I have the same problem
Old 06-11-2018, 00:25   #3 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,183
Thanks,
u need use z3x to install firmware and done
Old 06-11-2018, 06:19   #4 (permalink)
Member: 3691
Thanks Meter: 6
Try it with z3x and have the latest firmware but every time I get the error Sending abl.elf.lz4 ... error timeout. the error message appears on the boot and does not want to continue. The phone appears sw check fail [abl] Fused 4> Binary 3.So combination file FA 70 G955USQU4ARE1 does not have any problem, but any other firmware is experiencing a problem.
Old 06-11-2018, 06:37   #5 (permalink)
Member: 269202
Thanks Meter: 281
Hi
find binary 4 firmware
Old 06-11-2018, 08:08   #6 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,183
u need use lates z3x support lz4 and done
Old 06-11-2018, 08:42   #7 (permalink)
Member: 3691
Thanks Meter: 6
How to recognize which firmware is binary4. I can not find firmware with lz4 on suport z3x.
Old 06-11-2018, 09:08   #8 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,183
all Oreo 8.0 base on lz4
Old 06-11-2018, 09:25   #9 (permalink)
Member: 3691
Thanks Meter: 6
I tried using the latest firmware G955USQU3CRD4_OYN3CRD4\AP_G955USQU3CRD4_CL13001792 _QB17716807_REV01_user_low_ship_MULTI_CERT_meta.ta r.md5. but every time I try:Sending abl.elf.lz4... error timeout
Done with Samsung Tool PRO v.32.7
Old 06-11-2018, 09:30   #10 (permalink)
CHANDARAKK's Avatar
Member: 930280
Thanks Meter: 1,183
ok i try help u via teamviwer give me iD and pass or u can use odin 3.1.3
Old 06-11-2018, 09:41   #11 (permalink)
Member: 269202
Thanks Meter: 281
I tried using the latest firmware G955USQU3CRD4_OYN3CRD4\AP_G955USQU3CRD4_CL13001792_QB177168 07_REV01_user_low_ship_MULTI_CERT_meta.tar.md5. but every time I try:Sending abl.elf.lz4... error timeout
Hi
your firmware is binary 3
G955USQU3CRD4
your combination is binary 4
find any binary 4 firmware
The Following 2 Users Say Thank You to mohammadhadi For This Useful Post:
Old 06-11-2018, 10:02   #12 (permalink)
Member: 3691
Thanks Meter: 6
id:402 907 777
pass:8706
Old 06-11-2018, 10:08   #13 (permalink)
Member: 3691
Thanks Meter: 6
Originally Posted by mohammadhadi View Post
Hi
G955USQU3CRD4
Hi any link for download binary 4 firmware
Old 06-11-2018, 11:37   #14 (permalink)
Member: 2596108
Thanks Meter: 58
why did you even flash combo BIN4 for S8 series? The stock firmware is only up to BIN3 right now. lmao You could've flashed BIN3 combo. explain thought process
Old 06-11-2018, 11:56   #15 (permalink)
Member: 3691
Thanks Meter: 6
how can there be a combination of file bin4 and firmware original bin3 on support site.
Page generated in 0.26360 seconds with 9 queries
