Samsung G955U from sprint USA [Solved] after inserting the combination file G955USKU4ARE1 on samsung g955u for unlock the sim more can not install any firmware in the phone. The phone is in the factory binary mode and works on all SIM cards but can not install any firmware. Is there any solution for this issue.Does it have some U4 firmware so I can install it in the phone or some other solution. Thanks, |
/sub I have the same problem |
Try it with z3x and have the latest firmware but every time I get the error Sending abl.elf.lz4 ... error timeout. the error message appears on the boot and does not want to continue. The phone appears sw check fail [abl] Fused 4> Binary 3.So combination file FA 70 G955USQU4ARE1 does not have any problem, but any other firmware is experiencing a problem. |
Hi find binary 4 firmware |
How to recognize which firmware is binary4. I can not find firmware with lz4 on suport z3x. |
I tried using the latest firmware G955USQU3CRD4_OYN3CRD4\AP_G955USQU3CRD4_CL13001792 _QB17716807_REV01_user_low_ship_MULTI_CERT_meta.ta r.md5. but every time I try:Sending abl.elf.lz4... error timeout Done with Samsung Tool PRO v.32.7 |
Hi your firmware is binary 3 G955USQU3CRD4 your combination is binary 4 combination file FA 70 G955USQU4ARE1 find any binary 4 firmware |
id:402 907 777 pass:8706 |
why did you even flash combo BIN4 for S8 series? The stock firmware is only up to BIN3 right now. lmao You could've flashed BIN3 combo. explain thought process |
how can there be a combination of file bin4 and firmware original bin3 on support site. |
