09-06-2017, 23:58 | #1 (permalink) |
No Life Poster Join Date: Apr 2015 Location: Dominican Republic
Member: 2382052 Status: Offline Thanks Meter: 1,511 | Samsung g955u unlock msl done Unlocking with original MSL code: Warning! Knox warranty must be active (0x00)! If you have it voided (0x01(void)), then you can't unlock this phone with MSL. 1. Phone must be powered on. 2. Type *#0808# and select 'DM+ACM+ADB'. 3. Run dialer and type *#0*# (service mode will apear). 4. Connect the phone to USB cable, choose correct COM port in port settings. 5. Press 'Unlock' button. 6. Paste MSL code in new opened window and press 'OK'. Reading codes using sever: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Read Codes via server' button, write your login and password in window if it will apear. (Login and password will be saved as default after first input and can be changed in settings.) Operation: Unlock Selected model: SM-G955F Software version: 29.2 Searching Samsung modem... detectado COM467 Leyendo información del teléfono ... Listo Modelo: SM-G955F AP version: G955FXXU1AQDG CSC version: G955FUWE1AQDG CP version: G955FXXU1AQDG Código del Producto: DOR Phone SN: R58J62LAR5E Número único: CE05171569D668A60C Reading IMEI... Listo IMEI: 359122086378865 Reading SN... Listo Phone SN: R58J62LAR5 Enter MSL: 4C074E145F1F5142543D26233719470F Bypass MSL... Listo Desbloquear... Listo Codes set to 00000000 Reiniciando teléfono ... Listo Desbloqueo Listo Done with Samsung Tool PRO v.29.2 |
The Following User Says Thank You to maxpatri9 For This Useful Post: |
