05-02-2017, 08:33 | #1 (permalink) |
Freak Poster Join Date: Jan 2016 Location: Afghanistan
Member: 2520139 Status: Offline Sonork: masoudsoftware Thanks Meter: 300 | Samsung Galaxy Express 3 SM-J120A (new Security 2017)Unlock Done How To Root UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Read Codes Selected model: SM-J120A Software version: 28.1 Waiting ADB device... Ok Reading phone info... Model: SAMSUNG-SM-J120A Android version: 6.0.1 Product code: SM2J120AZWBATT Phone version: J120AUCU2APJ2 PDA version: J120AUCU2AQC1 CSC version: J120AATT2AQC1 CSC country code: USA CSC sales code: ATT HW version: REV0.3 Phone SN: R58J13NCGKT Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2017-03-01 RF cal date: 20170117 IMEI: Checking Super user right... true Reading NV data... Ok Checking NV data... Ok Reading data... Ok Detecting MODEM... Ok Reading MODEM... Ok Calculating... Ok Writing zTool... Ok Initialization zTool... Ok Running zTool, please wait... Start... Ok Initialization... Ok Generate and check client proof... Ok Verify proof by client... Ok Reading data... Ok HWID: E1 06 CC 3D 8C 59 03 E7 54 FF 53 E3 07 60 5A 57 Calculating... Ok Checking hash file... Ok Please wait, calculating codes... OK (time - 00:00:11) Freeze code: 37250704 NET lock: 86085151 SUB lock: 00000000 SP lock: 00000000 CP lock: 00000000 SIM lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool PRO v.28.1 If Give Erorr Flash This Firmware Samsung Galaxy Express 3 SM-J120A Firmware Android Version: 6.0.1 Product code: ATT (USA) PDA: J120AUCU2APJ2 CSC: J120AATT2APJ2 |
The Following 3 Users Say Thank You to masoudsoftwrae For This Useful Post: |
06-08-2017, 15:31 | #3 (permalink) | |
Insane Poster Join Date: Sep 2014 Location: somewhere in the world
Member: 2262745 Status: Offline Sonork: 167687 Thanks Meter: 11 | Quote: I am trying to solve my issue with this phone without using Odin. can you contact me via skype for some questions? | |
06-14-2017, 05:29 | #6 (permalink) |
Junior Member Join Date: Dec 2015
Member: 2501648 Status: Offline Thanks Meter: 3 | J120AUCS3AQE1 Android security patch level may 1, 2017 downgrade modem J120AUCU2APJ2 Baseband Version Unknow binary 3 modem patch security how can i unlock Samsung Galaxy Express 3 SM-J120A AT&T |
The Following User Says Thank You to maikellc For This Useful Post: |
06-16-2017, 15:19 | #8 (permalink) |
Insane Poster Join Date: Jan 2014 Location: algeria Age: 45
Member: 2114107 Status: Offline Sonork: 100.1652044 Thanks Meter: 15 | pleaaaaaaaaaaaaaaase i need this firmware J120AUCS3AQE1 unknown baseband after downgrade modem |
The Following User Says Thank You to kaibous44 For This Useful Post: |
06-17-2017, 00:31 | #9 (permalink) |
Freak Poster Join Date: Jul 2006
Member: 308068 Status: Offline Thanks Meter: 21 | Check this post link: http://forum.gsmhosting.com/vbb/f453...nlock-2204846/ Hope it helps |
06-17-2017, 05:24 | #10 (permalink) | ||||
Member: 2520139 Status: Offline Sonork: masoudsoftware Thanks Meter: 300 | Quote:
09-11-2017, 09:14 | #11 (permalink) |
Junior Member Join Date: Jun 2014 Location: Heart
Member: 2208050 Status: Offline Sonork: Rkdanish(1656528) Thanks Meter: 16 | S3 New Security Unlock UNLOCK INSTRUCTIONS: To unlock NEW security type: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options', go to 'Settings'-'Developer options' and enable 'USB debugging'. 3. Connect the phone to PC with USB cable, install drivers if needed. 4. Select device in ADB settings. 5. Press 'Unlock' button and select 'New Unlock' for direct unlock. To unlock OLD security type: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button and select 'Unlock' for direct unlock. To read security codes (all security types): 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Read codes' button to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect the phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Unlock Selected model: SM-J120A Software version: 29.2 Waiting ADB device... OK Reading phone info... Model: SAMSUNG-SM-J120A Android version: 6.0.1 Product code: SM2J120AZWCATT Phone version: J120AUCU3AQE1 PDA version: J120AUCS3AQE1 CSC version: J120AATT3AQE1 CSC country code: USA CSC sales code: ATT HW version: REV0.3 Phone SN: R58J70Z4QZF Chip name: EXYNOS3475 Modem board: SHANNON308 Security patch: 2017-05-01 RF cal date: 20170706 IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 59 12 4A E5 59 EB F5 6F 53 03 1A 19 BD 9E D7 DF Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.29.2 |
10-25-2017, 16:38 | #13 (permalink) | |
No Life Poster Join Date: May 2015
Member: 2395490 Status: Offline Thanks Meter: 515 | Quote:
The Following 3 Users Say Thank You to Alexandroid For This Useful Post: |
11-16-2017, 17:59 | #14 (permalink) |
Junior Member Join Date: Jun 2009
Member: 1049354 Status: Offline Thanks Meter: 1 | downgrade y unlock J120A At&T J120AUCS3AQE1 para el J120 At&T J120AUCS3AQE1 el modem version J120AUCU2APJ2 deja sin baseband para elñ usa el modem J120AUCU3AQE1 despues unlock con z3x sin root |
12-06-2017, 10:17 | #15 (permalink) | |
No Life Poster Join Date: Feb 2010 Location: Majuro, Marshall Islands
Member: 1227040 Status: Offline Sonork: 100:1654728 Thanks Meter: 55 | Quote: Reading phone info... Model: SAMSUNG-SM-J120A Android version: 6.0.1 Product code: Phone version: PDA version: J120AUCS3AQE1 CSC version: J120AATT3AQE1 CSC country code: USA CSC sales code: ATT HW version: Phone SN: R58J510NFVH Chip name: EXYNOS3475 Modem board: Security patch: 2017-05-01 RF cal date: IMEI: Checking Super user right... true Reading NV data... OK Checking NV data... OK Reading data... OK Detecting MODEM... OK Reading MODEM... OK Calculating... OK Writing zTool... OK Initialization zTool... OK Running zTool, please wait... Start... OK Initialization... OK Generate and check client proof... OK Verify proof by client... OK Reading data... OK HWID: 25 27 BB CA E0 2C 4B 37 47 4D 2D 3E 4A 01 C6 B1 Calculating... OK Unlocking... OK Writing NV data... OK Rebooting phone... OK Unlock done Done with Samsung Tool PRO v.30.1 Thank you sir! | |
