10-31-2016, 09:07 | #1 (permalink) |
No Life Poster Join Date: Nov 2015
Member: 2488031 Status: Offline Sonork: 100.1662695 Thanks Meter: 1,947 | Samsung Galaxy Grand Prime G531H FRP Reset Done By Z3X Box Samsung Galaxy Grand Prime G531H FRP Reset Done By Z3X Box Br Suny125 |
The Following 4 Users Say Thank You to Suny125 For This Useful Post: |
11-14-2016, 22:13 | #2 (permalink) |
Insane Poster Join Date: Aug 2006
Member: 330143 Status: Offline Thanks Meter: 4 | UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP/React/EE Selected model: SM-G531H Software version: 27.1 Searching Samsung USB Flash interface... not found Done with Samsung Tool PRO v.27.1 how it work it not detached |
11-14-2016, 22:20 | #3 (permalink) |
Member: 330143 Status: Offline Thanks Meter: 4 | UNLOCK INSTRUCTIONS: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. ADB must be activated in any way (you can flash sBoot from combination firmware, make sure, that you are not upgrade sBoot). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Select device in ADB settings. 4. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operation: Reset FRP Selected model: SM-G531H Software version: 27.1 Waiting ADB device... timeout Phone not found First activate ADB Done with Samsung Tool PRO v.27.1 how i m activate adb |
