10-17-2016, 20:44 | #1 (permalink) |
No Life Poster Join Date: Mar 2011 Location: dominican republic Age: 45
Member: 1537078 Status: Offline Sonork: celular center Thanks Meter: 573 | Samsung Galaxy On5 ( SM-G550T ) 6.0.1 Marshmallow FRP Remove z3x Supported Phone or Model :- Galaxy On5 or G550T or G550T1 Follow Instruction Below To Solve This Issue :- Download ENG_Boot_G550T_PG1_By_masterRt1994.tar From Here. Put Your Phone In Download Mode and Write This ENG_Boot_G550T_PG1_by_masterRt1994.tar Using ODin in ap or pda After Write ENG_Boot Your Phone Will Reboot To Normal - Amazing Part Is That Now ADB Debugging Is Enabled and Now u Know What U Need To dO. ENG_Boot_G550T_PG1_By_masterRt1994.tar download ENG_BOOT_G550T_PG1_by_masterRt1994 - Download - 4shared subir fotos online |
The Following 12 Users Say Thank You to chipscell25 For This Useful Post: |
11-02-2016, 05:07 | #2 (permalink) |
Junior Member Join Date: Jun 2015
Member: 2410377 Status: Offline Thanks Meter: 0 | This has not worked for me. Every attempt I get the: "Incorrect model selected. This may damage your phone. Continue?" Hitting "No" and trying again didn't work. If I hit continue, it times out eventually. Operation: Reset FRP Selected model: SM-G550T Software version: 27.0 Waiting ADB device... ok Reading phone info... Model: Android version: Product code: Phone version: PDA version: CSC version: CSC country code: CSC sales code: HW version: Phone SN: Chip name: Modem board: RF cal date: IMEI: Operation aborted Done with Samsung Tool PRO v.27.0 |
11-24-2016, 14:07 | #4 (permalink) |
Freak Poster Join Date: Jan 2007 Location: <Al hind al Garbiyya> Barbados
Member: 430155 Status: Offline Thanks Meter: 40 | Welcome to Octoplus/Octopus Box Samsung software version 2.4.3 ----------------------------------------------------------------------------------- To connect SM-G920A phone you have to perform the following steps: 1. Disconnect USB cable from phone. 2. Go to Menu->Settings->More->About Device. 3.Tap on "Build number" 7 times to enable developer options. 4. Go to Menu->Settings->More->Developer options. 5. Turn on "USB Debugging" option. ----------------------------------------------------------------------------------- Platform: Samsung Android Selected port: COM1 Selected model: SM-G550F Connecting to server... Connecting to server...Ok! Checking resource files... Downloading resources... All necessary resource files have been downloaded successfully. Please put the phone into Download Mode and connect USB cable. To put SM-G550F into Download Mode, You have to perform the following steps: 1. Reconnect the battery. 2. Press and hold "Volume-" + "Home" + "Power ON" keys. 3. When phone turns on, press "Volume+" key. Waiting for phone... Firmware write started. Writing Custom section... Custom section has been written successfully. FRP lock is successfully reseted! Wait 3-4 min then goto "Backup and reset" and make "Factory data reset" Performed by 2.4.3 Software version. |
02-08-2017, 15:22 | #8 (permalink) |
Freak Poster Join Date: Jul 2015 Location: Macedonia
Member: 2430631 Status: Offline Thanks Meter: 40 | Not working here on G550T. I suppose this boot is from older version of firmware, mine is the latest flashed through KIES 3 today. Anyone having compatible boot with the latest firmware? |
03-30-2017, 04:06 | #9 (permalink) |
Junior Member Join Date: May 2014
Member: 2196771 Status: Offline Thanks Meter: 0 | thanks file worked for me Using Version...1.0.0.0043 Selected Model SM-G550T1 Selected Task FRP REMOVE ADB Searching ADB device Please wait.. preparing Android first time use fix... Device Detected... model:= SM-G550T1 Androids Version:= 6.0.1 Description Version:= on5ltemtr-user 6.0.1 MMB29K G550T1UVU1APF1 release-keys Platform:= exynos3 [ universal3475 ] [ SHANNON308 ] Baseband:= G550T1UVU1APF1 VER:= G550T1UVU1APF1/G550T1TMK1APF1/G550T1UVU1APF1/G550T1UVU1APF1 Carrier := TMK_USA EFS CSC := TMK AP UART Status := Disable. Network Mode := LTE Simstatus:= READY ANDROID-ID = 4200533ef257733f_0000485A67 type1 root exploit possible. Device is not rooted ANDROID FRP REMOVE ADB STARTED... No ROOT FRP Bypass Started... !!! Success !!!! Restarted phone... Total Time Take...00:04:56 Log Saved |
02-18-2018, 15:06 | #11 (permalink) |
Junior Member Join Date: Aug 2013 Location: Guinée
Member: 1998817 Status: Offline Sonork: diallolama50 Thanks Meter: 1 | samsung sm-g550t frp unlock with octoplus box Welcome to Octoplus FRP Tool v.1.1.4 Platform: SAMSUNG Selected model: SM-G550T Searching for UART interface.. COM8 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Rebooting phone in Upload Mode...OK Please connect phone to USB cable.. Searching for a phone. Please wait...OK Reading data... Checking operation... Searching for UART interface.. COM8 Connect Samsung Micro UART cable(with 525K resistor), press and hold "Vol-" + "Power" buttons for 15-20 seconds Searching for device. Please wait... Phone found. Resetting FRP lock (1/2 attempt)..success FRP lock is successfully reseted! Performed by 1.1.4 Software version. |
