11-20-2011, 10:21 | #16 (permalink) | |
Crazy Poster Join Date: Mar 2008 Location: Philippines
Member: 737120 Status: Offline Sonork: 6124 Thanks Meter: 8 | Quote:
thanks brother good work, this solution is good | |
02-04-2012, 18:17 | #21 (permalink) |
Insane Poster Join Date: Dec 2003 Location: SLOVENIJA Age: 56
Member: 45771 Status: Offline Sonork: 1580823 Thanks Meter: 15 | boys ,when you while make master reset use adb program .... open it on comand prompt run adb.exe ....then write adb reboot recovery and finish .... no need flash and .... for this problem need 5 second ..... tray ...!!!! |
02-27-2012, 08:41 | #22 (permalink) |
No Life Poster Join Date: Apr 2011 Location: kerala
Member: 1550704 Status: Offline Sonork: 100.1644808 Thanks Meter: 248 | s5570 to many pattern attempts the problam will solved 100 %%%%% 1. pres the power botn + ok baton then 2. reset the phone 3. rebot the phone |
06-01-2012, 07:32 | #23 (permalink) |
Freak Poster Join Date: Apr 2005
Member: 140564 Status: Offline Thanks Meter: 16 | yes here is the solution TESTED 100% you can hard reset it keep Home +Power on for 15sec a black screen with blue and yellow fonts will apear scroll down with Volume Key to wipe data/factory reset select it by Home key and now select Yes _ _ delete all user phoen will restart and reset is done. |
06-18-2012, 10:37 | #24 (permalink) |
No Life Poster Join Date: Jun 2012 Location: tamil nadu, india Age: 35
Member: 1772238 Status: Offline Sonork: 100.1617698 Thanks Meter: 126 | 1. Power off phone 2. Press and hold Menu Button ( middle ) + power on for at least 10 seconds 3. Android System Recovery Mode Appear 4. There are 4 options reboot system now apply sdcard:update.zip wipe data/factory reset wipe cache partition 5. Move the options to " Wipe data / factory reset " using volume down ( - ) button and menu button to confirm, because the touchscreen doesn't work in reovery mode 6. After the process done, phone will reboot. |
08-29-2012, 08:27 | #25 (permalink) |
Freak Poster Join Date: Jul 2008 Location: kananga, leyte, philippines
Member: 817844 Status: Offline Sonork: junjie007 Thanks Meter: 17 | Code: Firmware Update Steps: 1:Run Samsung S5570 Galaxy Mini Downloader. 2:Select OPS file: Download 3:Click BOOT button and select: APBOOT_S5570xxxxx_xxx..._user_mid_false.tar.md5 4:Click Phone button and select: MODEM_S5570xxxxx_xxx...._REV02.tar.md5 5:Click PDA button and select: CODE_S5570xxxxx_xxx..._REV02_user_mid_false.tar.md 5 6:Click CSC button and select: CSC_S5570xxxxxx_xxx..._REV02_user_mid_false.tar.md 5 7:Put your phone into Download Mode: Press middle Key ( Home key ) + Power + Volume Down 8:Connect USB cable to your phone and the program must read the Com number it takes. 9:Click Start button and the update process will start. 10o not touch or remove anything till the device rebooted and you can see PASS word on the program. Firmware Download From here |
08-29-2012, 15:55 | #27 (permalink) | |
No Life Poster Join Date: Sep 2003 Location: latin america Age: 48
Member: 38642 Status: Offline Thanks Meter: 69 | Quote:
i need it's files .. but i can't download it.. help me pl bye br | |
logos, startup, ringtone, software and many more | mrENigma | GSM Mobile Links | 2 | 07-31-2001 23:53 |
Unlocking Software For MANY Models!!! | davieb | GSM Mobile Links | 0 | 06-30-2001 13:49 |
WWW.MOBBEN.COM - MobBen is Mobile Benefit..many benefits incl. free SMS,logosending.. | jsp_m | GSM Mobile Links | 0 | 05-30-2001 10:00 |
hope it is not too comercial | aleksj | Wanted Products | 0 | 06-12-2000 13:22 |
too | @ngelon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-02-2000 14:09 |
