12-10-2010, 17:02 | #1 (permalink) |
Freak Poster Join Date: Nov 2009 Location: India
Member: 1163538 Status: Offline Sonork: 100.1611793 Thanks Meter: 101 | Z3X Team Please Help Me Dear Z3X Team I Have A Problem with E2120I Restart I Have Flashed It With 3 Different Versions Then Also It was Going On restart Restart Problem Not Solved I have 3 Mobiles Same Model With Same Problem Versions Used E2120IDDJE1 E2120IDDJG2 E2120iDDJD6 Please Provide Me Good Flash Files |
12-10-2010, 17:11 | #2 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Ukraine Age: 51
Member: 40400 Status: Offline Thanks Meter: 1,250 | Now open your eyes and look closely on this thread : http://forum.gsmhosting.com/vbb/f453...ution-1147634/ |
09-10-2011, 14:56 | #3 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,109 | Unnecessary Solution PCB Not available in Market Any Body Know Where I Found This PCB Supplier |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
09-10-2011, 15:12 | #4 (permalink) | |
Freak Poster Join Date: Aug 2009 Location: bangladesh Age: 34
Member: 1104393 Status: Offline Sonork: 100.1603062 .::RONY::.. Thanks Meter: 130 | it's 1000% r8 solution i m tested many sat solve use this trick........... 1 (E2120iODDJE1_CSC) down load this file from z3x support area 2 select 2121b model then flace with 3 file Quote:
09-10-2011, 15:31 | #5 (permalink) |
No Life Poster Join Date: Apr 2010 Location: Lahore Pakistan. Age: 38
Member: 1284347 Status: Offline Sonork: 100.1592292 Thanks Meter: 977 | palash love2000 use hwk 1st erase nor 2nd flash it with latest ver an chk imei is 0000000000000 3rd write e2p file solve your problem 1000000000% i am solve this problem many time regard br, AM_GSM_CELL...:::AWAIS.AS:::... |
09-11-2011, 05:01 | #6 (permalink) |
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,109 | Only Possible Samsung 2120i Re-stat Solution By Hwk Don't Worry z3x Team File From z3x Server Flash By Hwk Code: MCU File: E2120iDDJD6.cla CRC32: 99EECAF7 TFS File: E2120iDDJD6.tfs CRC32: F4CE4271 CFG File: E2120iDDJD6.cfg 21316 byte(s) CSC File: E2120iODDJD6.csc CRC32: B68D2622 CCF File: E2120iODDJD6.ccf 7678 byte(s) Connect Cable to Switched Off Mobile (with battery) Preloader Ok 08, 921600 Baud Flashloader Ok FLASH Id: SEC, K5N5629ATA [NOR 256Mb] Erase Done, 120 sector(s), Time: 00:43 MCU MSL Patched Ok, Time: 00:09 File CRC: 0xB10AA051 MCU Write Done, 15754592 byte(s), Time: 05:54 File CRC: 0xF4CE4271 TFS Initialised: 1 TFS Version: TFS4.0_CORONA_01 Directories: 84 Max_Files : 257 Files_Count: 257/257 Files Closed TFS Unmounted TFS Write Done, 3546243 byte(s), Time: 01:23 CSC Format Done, Time: 00:03 File CRC: 0xB68D2622 TFS Version: TFS4.0_CORONA_01 Directories: 29 Max_Files : 91 Files_Count: 91/91 Files Closed CSC Unmounted CSC Write Done, 2229170 byte(s), Time: 00:51 E2P File: E2120_352502-03-xxxxxx-8_E2P.bin Connect Cable to Switched Off Mobile (with battery) Preloader Ok 08, 921600 Baud Flashloader Ok FLASH Id: SEC, K5N5629ATA [NOR 256Mb] E2P IMEI Patched Ok: 352502-03-054806-8 File CRC: 0xF0C71ECE E2P Write Done, 1048576 byte(s), Time: 00:21 Connect Cable to Switched Off Mobile (with battery) MSL Active MSL Deactivated SLOCK Reset, Ok Unlock Done |
Winlock 1.10 - Help | rdmfs | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-25-1999 08:21 |
