08-03-2016, 09:12 | #1 (permalink) |
Freak Poster Join Date: Dec 2009 Location: Oman+BD
Member: 1194197 Status: Offline Sonork: 100.1671026 Thanks Meter: 185 | Samsung Galaxy S6 Edge+ G928P Android 6.0.1 FRP Reset Done Samsung Galaxy S6 Edge+ G928P Android 6.0.1 FRP Reset Done By Faruk Patwary After Reset Frp |
The Following 5 Users Say Thank You to faruk_patwary For This Useful Post: |
08-10-2016, 16:34 | #2 (permalink) |
No Life Poster Join Date: Jun 2003
Member: 30754 Status: Offline Thanks Meter: 9 | earching Samsung USB Flash Interface... detected COM91 Setup connection... OK Reading PIT from phone... OK Searching FRP lock... OK Erasing FRP... OK Searching Reactivation lock... OK Erasing Reactivation lock... error Done with Samsung Tool PRO v.26.3 |
08-10-2016, 22:32 | #6 (permalink) |
Cheater -Don't Deal with him- Join Date: Feb 2016
Member: 2532914 Status: Offline Thanks Meter: 1,154 | 1. Downgrade sboot to 5.1.1 0I6 (DOWNLOAD HERE) 2. RESET FRP WITH Z3X 3. If phone is on 5.1.1 you are done FRP REMOVED. 4. If phone is on 6.0.1 flash 6.0.1 sboot back to phone or it will not boot up (DOWNLOAD HERE) ALL DONE!!! |
The Following 5 Users Say Thank You to markhaines1985 For This Useful Post: |
07-20-2017, 00:58 | #12 (permalink) |
No Life Poster Join Date: Nov 2004 Location: USA
Member: 92260 Status: Offline Thanks Meter: 843 | Downgrade to a 6.x.x firmware which has the SAME 4th digit as your current 7.x.x firmware. For example if your 7.x.x firmware is xxx"1"xxxx with its 4th digit = "1" Then flash it with a 6.x.x firmware xxx"1"xxxx with its 4th digit = "1" And of course if the 4th digit is a 2, 3 or 4 then you have to match that exactly. Sometimes it's hard to find a matching version, but it's out there. Or just use the new uart method, with no downgrading required. |
10-01-2017, 04:54 | #13 (permalink) | |
Freak Poster Join Date: Jun 2016
Member: 2592600 Status: Offline Thanks Meter: 19 | Quote:
error on marshmellow whats am i doing wrong | |
