11-25-2016, 13:25 | #20 (permalink) |
No Life Poster Join Date: Nov 2006 Location: *P*A*K*I*S*T*A*N
Member: 391445 Status: Offline Sonork: 100.1583575 Thanks Meter: 392 | U flashed the modem given in the link and modem Messed up rite Flash any stock firmware from z3x,you will get your imei and base band back |
11-25-2016, 13:28 | #21 (permalink) |
Freak Poster Join Date: Jan 2016 Location: Afghanistan
Member: 2520139 Status: Offline Sonork: masoudsoftware Thanks Meter: 300 | This solution is for XXS3 Security to fix your problom you need Flash This Firmware Download Firmware ? Samsung Update Baseband will be ok but for unlock no solution for now If You Can find XXS4 Combonion firmware You Will Chance to unlock |
11-26-2016, 07:02 | #22 (permalink) |
Freak Poster Join Date: Aug 2013 Location: Pakistan Gujrat
Member: 2000524 Status: Offline Sonork: 100.1679849 Thanks Meter: 13 | The result of your flash file is this Operation: Flash Selected model: SM-G920F Software version: 27.1 File analysis... ok Total file size: 0xE5A42A80 (3674 Mb) Searching USB Flash interface... COM5 detected Setup connection... ok Reading PIT from phone... ok Sending sboot.bin... ok Sending cm.bin... ok Sending boot.img... ok Sending recovery.img... ok Sending system.img... ok Sending modem.bin... ok Sending cache.img... ok Sending hidden.img... error timeout Done with Samsung Tool PRO v.27.1 what i do now ?? |
11-26-2016, 07:03 | #23 (permalink) | |
No Life Poster Join Date: Dec 2008
Member: 930280 Status: Offline Thanks Meter: 1,183 | Quote:
11-26-2016, 07:07 | #24 (permalink) | |
Member: 2000524 Status: Offline Sonork: 100.1679849 Thanks Meter: 13 | Quote:
but I faced Imei and baseband problem I flashed with XXS4DPG7_OLB3DPFV but face same problem and then I flash with down here given flash file link but It stucked please some one give me tested flash file please please hurry please | |
