09-05-2016, 15:56 | #16 (permalink) |
Insane Poster Join Date: May 1999 Location: ITALY Age: 52
Member: 75 Status: Offline Thanks Meter: 2 | Checking local file... Non trovato Ricerca server... OK File not found on server for this model Eseguito con Samsung Tool PRO v.26.6 |
09-05-2016, 22:19 | #17 (permalink) |
Major Poster Join Date: May 2014
Member: 2185147 Status: Offline Thanks Meter: 2 | I have this error every time some one can help? Operation: Reset FRP/React/EE Selected model: SM-G930F Software version: 26.5 Checking local file... OK Searching server... OK Compare local and server file... OK (up to date) Searching USB Flash Interface... detected COM7 Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... time out Phone not found Done with Samsung Tool PRO v.26.5 Trying to reset frp but i get this ! |
09-06-2016, 08:25 | #20 (permalink) |
Member: 75 Status: Offline Thanks Meter: 2 | UNLOCK ISTRUZIONI: 1. Power on the phone. 2. Connect the phone to PC with USB cable. 3. Check Samsung modem in device manager, install drivers if needed. 4. Press 'Unlock' button for direct unlock or 'Read codes' to read security codes. To reset Google account activation or Samsung reactivation lock: 1. Power on phone in download mode (turn off phone, press vol.down + home + power). 2. Connect phone to PC with USB cable, install drivers if needed. 3. Press 'Reset FRP/React/EE' to deactivate Google/Samsung/EE account activation lock. (Sometimes needs to perform 'wipe data/factory reset' once more, to complete this locks removal.) Operazione: Reset FRP/React/EE Modello selezionato: SM-G935F Versione software: 26.6 Checking local file... OK Ricerca server... OK Compare local and server file... OK (up to date) Ricenrca Interfaccia USB... Trovato COM11 Impostazioni connessione... OK Lettura dati da telefono... OK Sending data to phone... OK Scrittura device ADB... tempo scaduto Telefono non trovato Eseguito con Samsung Tool PRO v.26.6 |
11-28-2016, 12:32 | #23 (permalink) |
Junior Member Join Date: Jul 2015
Member: 2423006 Status: Offline Thanks Meter: 1 | Same problem with G935F , I did try to remove FRP and / or DRK from the phone by Z3X per last 4 weeks but no look at all , why z3x have this option if it is not working at all . I did flash combination firmware but it do nothing to help remove any FRP or DRK . z3x is working perfect with the phones up to samsung s6 . in 4 months samsung s8 will be out but I dont see how will it work if we are still not able to sort out s7 yet . This is a big problem . |
02-12-2017, 15:35 | #25 (permalink) |
Junior Member Join Date: Jan 2017
Member: 2669283 Status: Offline Thanks Meter: 0 | can't activate adb mode on G935w8 to reset FRP hi, i put my s7edge in download mode,i click on ResetFRP,its asking to put phone in ADB mode, i can't access to settings to activate it,of course because of FRPLock any ideas how to activate ADB from this stage , i tried to flash combinations its very difficults to find one for my model, more details: s7edge SM-G935W8 (canada) Z3X V27,7 no important data on phone |
02-16-2017, 13:49 | #27 (permalink) |
Junior Member Join Date: Dec 2003 Location: bulgaria Age: 52
Member: 46489 Status: Offline Thanks Meter: 3 | Setup connection... OK Reading data from phone... OK Sending data to phone... OK Waiting ADB device... time out Phone not found 2 phone already written me this and it is not, then the phone died. Someone has found a solution. |
03-20-2017, 16:16 | #28 (permalink) |
Freak Poster Join Date: Apr 2002 Location: Sofia Age: 48
Member: 10948 Status: Offline Thanks Meter: 14 | Checking local file... Ok Searching server... Ok Compare local and server file... OK (up to date) Searching USB Flash interface... COM40 detected Setup connection... Ok Reading data from phone... Ok Sending data to phone... Ok Waiting ADB device... timeout Phone not found Done with Samsung Tool PRO v.27.8 at the moment its stay on logo screen and cant get in download mode. |
03-21-2017, 07:05 | #30 (permalink) |
Junior Member Join Date: Mar 2017
Member: 2697825 Status: Offline Thanks Meter: 0 | I am having the following issue on FRP remove for 935F via Z3X. Any ideas??? Thanks in advance. Operation: Reset FRP/React/EE Selected model: SM-G935V Software version: 27.8 Checking local file... Ok Searching server... Ok Compare local and server file... OK (up to date) Searching USB Flash interface... COM5 detected Setup connection... error |
