08-31-2018, 15:56 | #46 (permalink) |
Freak Poster Join Date: Sep 2010 Location: Ukraine, Ivano-Frankivsk Age: 31
Member: 1397329 Status: Offline Thanks Meter: 73 | Code: Microsoft Windows [Version 6.1.7600] (c) Корпорация Майкрософт (Microsoft Corp.), 2009. Все права защищены. C:\Users\JTAG>cd c:\sdb c:\sdb>sdb connect 192.168.0.122:26101 192.168.0.122:26101 is already connected c:\sdb>sdb push empty.bin /home/owner/media/Others/ pushed empty.bin 100% 256KB 1 file(s) pushed. 0 file(s) skipped. empty.bin 335 KB/s (262144 bytes in 0.763s) c:\sdb>sdb root on Switched to 'root' account mode c:\sdb>sdb shell sh-3.2# dd if=/home/owner/media/Others/empty.bin of=/dev/mmcblk0p15 512+0 records in 512+0 records out 262144 bytes (262 kB) copied, 0.0520023 s, 5.0 MB/s sh-3.2# reboot download Rebooting with argument 'download'. |
The Following 4 Users Say Thank You to Dimidrolus For This Useful Post: |
09-16-2018, 17:59 | #47 (permalink) |
No Life Poster Join Date: Aug 2007 Location: Algeria
Member: 574410 Status: Offline Thanks Meter: 93 | I have r-732 R/L:ON i test RLoff_SMr720andSMr732_p14_v1 but no success still R/L:ON https://www.4shared.com/photo/-oPECuGYgm/IMG_0706.html https://www.4shared.com/photo/8bA8ZZxOee/Untitled.html Any help |
The Following User Says Thank You to karim1980 For This Useful Post: |
09-18-2018, 03:58 | #48 (permalink) |
No Life Poster Join Date: Dec 2006 Location: yes
Member: 420658 Status: Offline Thanks Meter: 211 | @karim1980 Thanx for both Photos/Screenshot... This is not working with normal Stock Firmware... because ROOT access required. You need mandatory Combination Firmware... For instance from here: https://shell.boxwares.com/default.a...ll#fh5co-table WARNING! NOt use this Firmware for Live Demo Unit! Code: R732XXXU2AOI8 You need only 2 X in filename: Code: R732XXU2AOJ2 Best Regards |
The Following 2 Users Say Thank You to adfree For This Useful Post: |
09-19-2018, 01:04 | #50 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | @karim1980 I can see only 2 of 4 Links... no idea why... I see you have Combination Firmware... because Engineer Bootloader (sboot) visible... Please do this and Copy and Paste only text... Code: sdb root on Result should look like this: Code: c:\sdb>sdb root on Switched to 'root' account mode next Code: sdb devices next Code: sdb shell next Code: whoami NO Photo need... only text Copy and Paste please... Best Regards |
The Following 3 Users Say Thank You to adfree For This Useful Post: |
09-19-2018, 04:41 | #51 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | @karim1980 Please ignore previous post... Now I was able to see the 2 missing Pics... Try this: Code: sdb root on sdb shell dd if=/dev/zero of=/dev/mmcblk0p14 sdb shell reboot download @Others Warning!!! This is only for SM-R732 and SM-R720... Because partition p14... NOT try with other device without changing to correct STEADY partition number... Otherwise you will kill wrong partition! Best Regards |
09-19-2018, 17:11 | #52 (permalink) | |
Member: 574410 Status: Offline Thanks Meter: 93 | Quote:
My watch now works well with the R732_XXU2BOKK_OXA2BOKK and reactivation off. | |
09-20-2018, 08:21 | #53 (permalink) |
Freak Poster Join Date: Mar 2014
Member: 2138290 Status: Offline Thanks Meter: 26 | dd: writing to `/dev/mmcblk0p14': No space left on device i keep on getting this when i do the last part. maybe this is keeping it from clearning the RL any help will help me |
09-21-2018, 22:38 | #56 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | Code: COMBINATION-FT40_R800XXU1ARI2.tar.md5 Seems first Combination for 1 Galaxy Watch is available... Please. Can somebody share 1 Galaxy Watch Firmware... I have ZERO nothing... no files for investigation... Nor PIT... Maybe somebody can PM me. Thanx in advance. Best Regards |
The Following User Says Thank You to adfree For This Useful Post: |
09-30-2018, 00:49 | #60 (permalink) |
Member: 420658 Status: Offline Thanks Meter: 211 | About Galaxy Watch SM-R8... series... 1. Steady partition size seems same... Maybe procedure could be the same... SM-R800 and SM-R810 have STEADY on: Code: p19 SM-R815U on: Code: p21 2. Few Combination FirmwareS leaked... Best Regards |
