Old 07-17-2019, 22:31   #106 (permalink)
zeroualot_7's Avatar
Member: 112112
Sonork: 100.1621373
Thanks Meter: 171
SM-R810 tested and working
Originally Posted by adfree View Post
Still I have no feedback from Galaxy Watch users...
So no idea if work...
UNTESTED... OWN RISK!
I have renamed 1 Batch file... removed "test" in filename...
Because meanwhile SM-R600 STEADY partition p17 confirmed.
Added 2 new Batch files... Galaxy Watch SM-R8... related...
TIZEN_4_untested_GalaxyWatch_LTEseries_smR805_smR815_p21_v1.bat
TIZEN_4_untested_GalaxyWatch_smR800_smR810_p19_v1.bat
p19 and p21...
Best Regards
v8 tested and working
E:\reactivation lock gear\RLoff_v7\RLoff_v8>sdb connect 192.168.1.186:26101
192.168.1.186:26101 is already connected
E:\reactivation lock gear\RLoff_v7\RLoff_v8>sdb root on
Switched to 'root' account mode
E:\reactivation lock gear\RLoff_v7\RLoff_v8>sdb push empty.bin /home/owner/media/Others/
pushed empty.bin 100% 256KB
1 file(s) pushed. 0 file(s) skipped.
empty.bin 127 KB/s (262144 bytes in 2.000s)
E:\reactivation lock gear\RLoff_v7\RLoff_v8>sdb shell dd if=/home/owner/media/Others/empty.bin of=/dev/mmcblk0p19
512+0 records in
512+0 records out
262144 bytes (262 kB) copied, 0.0435614 s, 6.0 MB/s
E:\reactivation lock gear\RLoff_v7\RLoff_v8>sdb shell reboot download
Rebooting with argument 'download'.
The Following User Says Thank You to zeroualot_7 For This Useful Post:
Old 07-23-2019, 21:05   #107 (permalink)
Member: 575293
Thanks Meter: 34
Big thanks to adfree! R730 RL removed!
You have helped me clear off RL on R730 but it wasnt easy! Your instructions are not easy to follow but I was determined to get it done.
You dont mention that the batch files have the commands to use for the specific watches, I figured it out and got my watch working!
C:\tizen-studio\tools>sdb push empty.bin /home/owner/media/others
WARNING: Your data are to be sent over an unencrypted connection and could be read by others.
pushed empty.bin 100% 256KB 0KB/s
empty.bin 704KB/s (262144 bytes in 0.363s)
C:\tizen-studio\tools>sdb shell dd if=/home/owner/media/others/empty.bin of=/dev/mmcblk0p26
dd: opening `/home/owner/media/others/empty.bin': Not a directory
C:\tizen-studio\tools>sdb push empty.bin /opt/usr/media/
empty.bin 739KB/s (262144 bytes in 0.346s)
C:\tizen-studio\tools>sdb shell dd if=/opt/usr/media/empty.bin of=/dev/mmcblk0p26
512+0 records in
512+0 records out
262144 bytes (262 kB) copied, 0.0785324 s, 3.3 MB/s
C:\tizen-studio\tools>sdb shell reboot download
Many thanks again!
The Following User Says Thank You to cellfonepimp For This Useful Post:
Old 08-06-2019, 04:42   #108 (permalink)
Member: 2921990
I bought s3 frontier r765t on Ebay a and I received it was reactivation lock does anyone have the files to fix this for me
Old 08-06-2019, 04:43   #109 (permalink)
Member: 2921990
R765t reactivation lock
Old 08-06-2019, 04:43   #110 (permalink)
Member: 2921990
Old 08-06-2019, 04:45   #111 (permalink)
Member: 2921990
I have the r765t with reactivation lock does anyone have the files to fix this problem for me
Old 08-06-2019, 04:45   #112 (permalink)
Member: 2921990
Old 08-22-2019, 18:57   #113 (permalink)
ribbentrop's Avatar
Member: 40400
Thanks Meter: 1,094
Big thanks to adfree for idea and investigation R730A R\L removed
Microsoft Windows [Version 6.1.7601]
2012, (c) Корпорация Майкрософт. Все права защищены.
o:\r730a\3>adb devices
* server not running. starting it now on port 26099 *
* server started successfully *
List of devices attached
acc1c3004100c408 device SM-R730A
o:\r730a\3>adb root on
o:\r730a\3>adb push empty.bin /opt/usr/media/
empty.bin 472 KB/s (262144 bytes in 0.541s)
o:\r730a\3>adb shell dd if=/opt/usr/media/empty.bin of=/dev/mmcblk0p26
512+0 records in
512+0 records out
262144 bytes (262 kB) copied, 0.044174 s, 5.9 MB/s
o:\r730a\3>adb shell reboot download
o:\r730a\3>
The Following User Says Thank You to ribbentrop For This Useful Post:
Old 09-04-2019, 22:36   #114 (permalink)
Member: 420658
Thanks Meter: 161
Short looked into partition.pit of SM-R820 and SM-R830...
Looks like both have STEADY partition on p20
Best Regards
Old 09-10-2019, 08:12   #115 (permalink)
Member: 2488318
Thanks Meter: 27
Downloaded r765t Combination file fron AddFree. File will not open. Says corrupt file.
Old 09-11-2019, 10:58   #116 (permalink)
Member: 2926650
I succesfully Removed reactivation lock on my R815U i can confirm it work using RLoff_v8, thank you to all guys.
Please can someone confirm that R815USQU1BSE3 is the latest firmware for R815U .
The Following User Says Thank You to Apiso For This Useful Post:
Old 11-04-2019, 01:00   #117 (permalink)
Member: 420658
Thanks Meter: 161
Added Active and Active 2 for testing...
SM-R500 p20
SM-R820 and SM-R830 p20
SM-R825/SM-R835 LTE p22
Still own risk.
Best Regards
The Following User Says Thank You to adfree For This Useful Post:
Old 11-07-2019, 02:24   #118 (permalink)
Member: 2816155
Thanks Meter: 2
This worked for me on R730V (verizon)
512+0 records in
512+0 records out
Many thanks again!
The Following User Says Thank You to n3vr For This Useful Post:
Page generated in 0.44518 seconds with 8 queries
