09-18-2016, 16:21 | #1 (permalink) |
Junior Member Join Date: Apr 2016
Member: 2565480 Status: Offline Thanks Meter: 0 | Samsung GT-i9195 dead, Z3X error I connected to the ADAPTER Z3X Easy-Jtag, I did the research of the pinout but when I try to repair I get this error: Starting target communication ... Detecting EMMC memory parameters of bank (0) ... embeddedice handshake timeoutTimeout Error while reading approx: 0x00000008 bytes over DCC ERROR: No answer loader DCC Loader Init Failed! BUG: EMMC unknown controller initialization failure Enclose full log Code: Starting Z3X Jtag Pin Finder... Successfully connected to box on COM7 Waiting for box reset... Box S/N: 000000002C1F92ED Box Working Mode: JTAG Pin Finder. Starting Z3X Jtag Pin Finder... Stage 1: Search TCK / TMS / TDI / TDO... Get IDCODE... JTAG Pinout Found: TCK: Pin 9 / TMS: Pin 7 / TDI: Pin 5 / TDO: Pin 13 CPU IDCODE : 0x4F1F0F0F Mfg.: 0x787, Part: 0xf1f0, Ver.: 0x4 CPU Manufacturer: Samsung , CPU Name: ARM7GEN Stage 2: Searching TRST... TRST Pin Found: TRST: Pin 3 Box S/N: 010050082C1F92ED, ,FW Ver.: 01.55 Box Working Mode: JTAG Box. Using EasyRepair Mode... Warning , you are using custom pinout config make shure that NRST and GND on proper places! Checking repair data... EasyJtag Suite ver.: 2.3.0.1 / wxWidgets 3.1.0-W-U started. Operating system ver.: Windows 8 (build 9200), 64-bit edition. For support and updates visit #easy-jtag# Check security... OK Initialising: SAMSUNG GT-I9195 Config ver.:1.02 I/O Level set to : 2200 mV Box S/N: 010050082C1F92ED ,FW Ver.: 01.55 Connecting to Target... JTAG device: MSM8930AB. CPU IDCODE : 0x4F1F0F0F Mfg.: 0x787, Part: 0xf1f0, Ver.: 0x4 CPU Manufacturer: Samsung , CPU Name: ARM7GEN JTAG device: MSM8930AB. CPU IDCODE : 0x308930E1 Mfg.: 0x070, Part: 0x0893, Ver.: 0x3 CPU Manufacturer: QUALCOMM , CPU Name: Unknown Halting CPU... Initialize hardware... Starting target communication...Detecting emmc memory parameters of bank (0) ... embeddedice handshake timeoutTimeout Error while reading approx : 0x00000008 bytes over DCC ERROR: No loader answer DCC Loader init Failed! BUG: emmc unknown controller initialization failure The PC will recognize it as: Qualcomm HS-USB QDLoader 9008 Using USB cable and battery charger My goal is to repair the phone or at least to recover the data, but the beginner with this device. |
09-21-2016, 00:30 | #4 (permalink) |
Member: 2565480 Status: Offline Thanks Meter: 0 | I get the following error: Code: Z3X EasyJtag Software ver. 2.2.0.2 Loading eMMC Addon Firmware... IO: 2800 mV Box S/N: 010050082C1F92ED, ,FW Ver.: 01.55CMD Pullup Level:2722 mV CMD Active Level:2763 mV Box IO Level:2800 mV CLK Rate:1000 khz HiPower mode is off! Can't init device, Reason: CMD Timeout Error Done. 3w .rifugiodalpiaz. com/rifugiodalpiaz. com/temp/1 .jpg 3w. rifugiodalpiaz. com/rifugiodalpiaz. com/temp/2 .jpg 3w. rifugiodalpiaz. com/rifugiodalpiaz. com/temp/3 .jpg 3w. rifugiodalpiaz. com/rifugiodalpiaz. com/temp/4 .jpg 3w. rifugiodalpiaz. com/rifugiodalpiaz. com/temp/5 .jpg |
