08-13-2013, 18:59 | #1 (permalink) |
Freak Poster Join Date: Nov 2008 Location: Liberia
Member: 902377 Status: Offline Thanks Meter: 64 | Samsung i437p unlocked successfull ....... SELECT MODEL I437 IN Z3X TOOL . TYPE ON PHONE *#7284# THEN SELECT MODEM. PRESS DIRECT UNLOCK.... |
The Following 2 Users Say Thank You to vickybaljit For This Useful Post: |
09-29-2013, 16:49 | #2 (permalink) |
Freak Poster Join Date: Aug 2011
Member: 1637268 Status: Offline Sonork: 100.1606882 Thanks Meter: 18 | help me Selected model: I437 Selected port: COM3 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M8960A-AAAANAZM-2.0.01093 Reading security... error access denied Done with Samsung Tool v.15.7 |
The Following User Says Thank You to DeyviBox For This Useful Post: |
10-08-2013, 10:50 | #5 (permalink) |
No Life Poster Join Date: Jul 2013 Location: uganda
Member: 1976974 Status: Offline Sonork: 100.1641825 Thanks Meter: 92 | Selected model: I437 Selected port: COM8 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M8960A-AAAANAZM-2.0.01080 Reading security... OK Searching server... OK NET lock: #7465625*638*60520597# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung Tool v.15.9 |
10-08-2013, 10:53 | #6 (permalink) |
Member: 1976974 Status: Offline Sonork: 100.1641825 Thanks Meter: 92 | samsung I437 at&t read code Selected model: I437 Selected port: COM8 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M8960A-AAAANAZM-2.0.01080 Reading security... OK Searching server... OK NET lock: #7465625*638*60520597# Sub lock: #7465625*782*00000000# SP lock: #7465625*77*00000000# CP lock: #7465625*27*00000000# For check lock status: *#7465625# Done with Samsung Tool v.15.9 |
10-17-2013, 16:53 | #7 (permalink) |
Freak Poster Join Date: Jan 2004
Member: 48492 Status: Offline Thanks Meter: 29 | Mg3 firmware Selected model: I437 Selected port: COM4 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M8960A-AAAANAZM-2.0.01093 Reading security... error access denied Done with Samsung Tool v.16.0 |
10-31-2013, 16:07 | #9 (permalink) |
Freak Poster Join Date: May 2007 Location: Nic@r@gu@ Age: 41
Member: 516363 Status: Offline Sonork: 100.1601307 Thanks Meter: 35 | Samsung i437 Free Unlock Solution Just follow this steps. To root your phone do this: Executing Express-OUDHS-CWM. Create a backup via CWM. Wipe data/factory reset, wipe cache partition and dalvik cache (found in advanced) Download 4.0.4 firmware from ************** SGH-I437 USA (AT&T) 4.0.4 This firmware is for the model i437, not for i437P, but works. You goin to lose Wifi but donīt worry. Use Odim and put 4.0.4 firmware. You goin to lose root, but no problem. Donīt use any sim card for now. Lets unlock the phone using this code: Just dial the following keys *#197328640# Main Menu [1] UMTS [1] Debug Screen [8] Phone Control [6] Network Lock [3]Perso SHA256 OFF (after choosing this option, wait about 30 seconds, then go back one step by pressing the Menu button then select Back, now you are in [6] Network Lock then choose [4] NW Lock NV Data INITIALLIZ ..... wait for a minute then reboot your phone put your sim card and your phone is unlocked. Now lets upgrade repeat the steps to root your phone with Express-OUDHS-CWM Restore the backup made by clockworkmod. "You will likely run into issues with non functional WiFi. To resolve this, after flashing the ROM, follow these simple step:" Flash I437-UCDMG3-bootloader_update via ODIN in bootloader tap Then install CM10.2 that works FINE!!! Now lets intall GAPPS for CM10.2. Now ENJOY... |
11-26-2013, 21:48 | #11 (permalink) | |
No Life Poster Join Date: Jan 2006 Location: JAMAICA Age: 46
Member: 220143 Status: Offline Thanks Meter: 108 | Quote:
Code: Selected model: I437 Selected port: COM180 Z3X BOX Serial Port Selected port speed: 115200 Reading phone info... Build: M8960A-AAAANAZM-2.0.01093 Done with Samsung Tool v.16.1 | |
