samsung i5503 how to reset user code with zx3 |
i900,i5700,i5500,i5503 and other samsung full reset tricks Tested I900 Hard Reset Codes Step by Step Follow The Tricks To Get 1. REMOVE BATTERY & PUT IT BACK 2. HOLD VOLUME UP BUTTON & MIDDLE BUTTON (HOME BUTTON) 3. WHILE HOLDING THIS TWO BUTTON PRESS POWER BUTTON AND REALEASE(PRESS POWER BUTTON ONLY ONCE) 4.IT WILL POP UP WITH HARD RESET MENU 5. SCROLL DOWN TO FACTORY RESET WITH VOLUME DOWN BUTTON THEN PRESS CENTER BUTTON OR HOME BUTTON 6. THEN PRESS VOLUME DOWN BUTTON TO SELECT YES FACTORY SETTINGS THEN PRESS CENTER BUTTON 7. SELECT REBOOT DEVICE AND PRESS CENTER BUTTON TESTED 1000% WORKING Tested in I5503 Full Reset Volume UP + Home + Power and you should get the options menu reset. tested in a new samsung galaxy Aya Balo Labat Karuman(ito bago lang kahapon) Before you decide to flash the phone, try this should help in most cases... First insert correct sim card power the phone and wait until the phone turns on, call the card from another phone and answer the call ... while the connection is activated, press the back button and you'll be in the menu, go into the dialer and click on the new call while the old is still active, then enter * 2767 * 3855 # and phone will return to the factory defaults on the condition as when it was taken out of the box .... make sure the connection must be switched on at all times while on the menu. Dagdag pa...... Samsung Android Secret Codes *#*#4636#*#* - Phone Information [/URL]*2767*3855# - Hard Reset *#*#7780#*#* - Factory Reset *#*#7594#*#* - Change End Call/Power Option *#*#197328640#*#* - Service Mode *#*#273283*255*663282*#*#* - File Copy Screen (Backup Media Files) *#*#526#*#* - WLAN Test *#*#232338#*#* - Shows WiFi MAC address *#*#1472365#*#* - GPS Test *#*#1575#*#* - Another GPS test *#*#232331#*#* - Bluetooth test *#*#232337#*# - Shows Bluetooth device address *#*#8255#*#* - GTalk Service Monitor Codes to launch various Factory Tests: *#*#0283#*#* - Packet Loopback *#*#0*#*#* - LCD test *#*#0673#*#* - Melody test *#*#0842#*#* - Device test (Vibration test and BackLight test) *#*#2663#*#* - Touch screen version *#*#2664#*#* - Touch screen test *#*#0588#*#* - Proximity sensor test *#*#3264#*#* - RAM version Codes to get Firmware version information: *#*#4986*2650468#*#* - PDA, Phone, H/W, RFCallDate *#*#1234#*#* - PDA and Phone *#*#1111#*#* - FTA SW Version *#*#2222#*#* - FTA HW Version *#*#44336#*#* - PDA, Phone, CSC, Build Time, Changelist number |
[QUOTE=haron_d;7086416]i900,i5700,i5500,i5503 and other samsung full reset tricks Tested I900 Hard Reset Codes Step by Step Follow The Tricks To Get 1. REMOVE BATTERY & PUT IT BACK 2. HOLD VOLUME UP BUTTON & MIDDLE BUTTON (HOME BUTTON) 3. WHILE HOLDING THIS TWO BUTTON PRESS POWER BUTTON AND REALEASE(PRESS POWER BUTTON ONLY ONCE) 4.IT WILL POP UP WITH HARD RESET MENU 5. SCROLL DOWN TO FACTORY RESET WITH VOLUME DOWN BUTTON THEN PRESS CENTER BUTTON OR HOME BUTTON 6. THEN PRESS VOLUME DOWN BUTTON TO SELECT YES FACTORY SETTINGS THEN PRESS CENTER BUTTON 7. SELECT REBOOT DEVICE AND PRESS CENTER BUTTON TESTED 1000% WORKING Tested in I5503 Full Reset Volume UP + Home + Power and you should get the options menu reset. tested in a new samsung galaxy Aya Balo Labat Karuman(ito bago lang kahapon) Before you decide to flash the phone, try this should help in most cases... First insert correct sim card power the phone and wait until the phone turns on, call the card from another phone and answer the call ... while the connection is activated, press the back button and you'll be in the menu, go into the dialer and click on the new call while the old is still active, then enter * 2767 * 3855 # and phone will return to the factory defaults on the condition as when it was taken out of the box .... make sure the connection must be switched on at all times while on the menu. Dagdag pa...... Samsung Android Secret Codes *#*#4636#*#* - Phone Information [/URL]*2767*3855# - Hard Reset *#*#7780#*#* - Factory Reset *#*#7594#*#* - Change End Call/Power Option *#*#197328640#*#* - Service Mode *#*#273283*255*663282*#*#* - File Copy Screen (Backup Media Files) *#*#526#*#* - WLAN Test *#*#232338#*#* - Shows WiFi MAC address *#*#1472365#*#* - GPS Test *#*#1575#*#* - Another GPS test *#*#232331#*#* - Bluetooth test *#*#232337#*# - Shows Bluetooth device address *#*#8255#*#* - GTalk Service Monitor Codes to launch various Factory Tests: *#*#0283#*#* - Packet Loopback *#*#0*#*#* - LCD test *#*#0673#*#* - Melody test *#*#0842#*#* - Device test (Vibration test and BackLight test) *#*#2663#*#* - Touch screen version *#*#2664#*#* - Touch screen test *#*#0588#*#* - Proximity sensor test *#*#3264#*#* - RAM version Codes to get Firmware version information: *#*#4986*2650468#*#* - PDA, Phone, H/W, RFCallDate *#*#1234#*#* - PDA and Phone *#*#1111#*#* - FTA SW Version *#*#2222#*#* - FTA HW Version *#*#44336#*#* - PDA, Phone, CSC, Build Time, Changelist number[/QUOT any solution pls no luck for me... |
boss ilan beses q poh trinay.....ayw lumabas ng hard reset menu..pero tnx sdin poh ....... |
samsung i5530 hard reset not work ..................any solution |
samsung i5530 hard reset not work ... |
not working not working for i5503 |
I try this, is not working for i5503 |
