12-27-2013, 06:36 | #17 (permalink) |
Junior Member Join Date: May 2006 Location: Dallas Texas
Member: 282766 Status: Offline Thanks Meter: 14 | i got it to work also! ok for others that cant figure it out. if you have an att i747 s3 on 4.3 MJB bootloader and are getting the "Reading security... error access denied" when unlocking all you have to do is make sure your phone is rooted and has supersu installed with the KNOX security disabled ( it asks you when you run supersu for the first time if you want to disable it). then connect your phone to the z3x box ( i did usb cable not the 3300k cable) and like stated before you repair the imei using your imei from the back but make sure the repair network and repair efs setting are ticked. after it resets once and when it finishes the repair i manually rebooted again. afterwards i put my tmobile sim and boom it was unlocked! i actually put a different imei just to make sure it worked the first time and then redid the imei repair with my correct imei, thats how i figure it out.. anyways thanks Z3X team!!! |
The Following 2 Users Say Thank You to mr_kill_666 For This Useful Post: |
12-27-2013, 18:22 | #18 (permalink) |
Junior Member Join Date: Oct 2013
Member: 2054981 Status: Offline Thanks Meter: 7 | First *#7284# -> MODEM and in the same menu go Qualcomm USB Settings and choose DM + MODEM + ADB. Connect phone with UART Cable in z3x use T999 ase model! Selected model: I747 Selected port: COM9 Z3X Box Serial Port Selected port speed: 115200 Reading phone info... Build: M8960A-AAAANAZM-1.0.443030 Done with Samsung Tool v.16.3 Selected model: I747 Selected port: COM9 Z3X Box Serial Port Selected port speed: 115200 Reading phone info... Build: M8960A-AAAANAZM-1.0.443030 Reading security... OK Calculating... OK Writing security... OK Reseting... Unlock done Done with Samsung Tool v.16.3 Tested and works. (AT&T Device tested in germany with T-Mobile DE SIM) |
01-12-2014, 11:40 | #19 (permalink) |
No Life Poster Join Date: Nov 2005 Location: india Age: 45
Member: 201107 Status: Offline Sonork: 100.1576954 Thanks Meter: 737 | Selected model: I747M Selected port: COM94 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reading phone info... Build: M8960A-AAAANAZM-1.0.443100 Done with Samsung Tool v.16.8 Selected model: I747M Selected port: COM94 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Checking phone at COM94 Repairing IMEI... OK Repairing network settings... OK Reseting... OK Repair done Done with Samsung Tool v.16.8 I747M 4.3 UNLOCK IMEI REPAIR DONE ROOT PHONE MANNUALLY FIRST. B.R. kalpesh varia |
The Following 3 Users Say Thank You to PARMATMA For This Useful Post: |
01-15-2014, 03:51 | #20 (permalink) |
Crazy Poster Join Date: Aug 2013
Member: 2013147 Status: Offline Thanks Meter: 2 | ok guys here's what you have to do... make sure the phone is rooted first, dial *#7284# set your phone to PDA Second, dial *#0808# set your phone to dm+modem+adb connect with USB, NOT UART ! go into samsung tool and set the model to T999 go into repair, repair the network and EFS, and change your IMEI click ok, and let it do it's thing.. after it reboots the phone, it will show no network. reboot manually after it is fully booted. UNLOCKED !!! Build: M8960A-AAAANAZM-1.0.443089 Reading security... error access denied Done with Samsung Tool v.16.8 Selected model: T999 Selected port: COM51 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... Please, allow USB debugging on phone... OK Reading phone info... Model: SAMSUNG-SGH-I747 Android version: 4.3 Product code: SGH2I747MBBATT Phone version: I747UCUEMJB PDA version: I747UCUEMJB CSC version: I747ATTEMJB IMEI: ******059738125 Phone S/N: R31DB0ATNCP Checking Super user right... true Writing data to phone... OK Rebooting phone... OK Checking phone at COM51 OK Repairing IMEI... OK Repairing network settings... OK Reseting... OK Repair done Done with Samsung Tool v.16.8 Done with Samsung Tool v.16.8 |
The Following User Says Thank You to allisonmagic For This Useful Post: |
02-27-2014, 02:21 | #21 (permalink) |
Junior Member Join Date: Sep 2013
Member: 2021716 Status: Offline Sonork: www.sonork.com Thanks Meter: 2 | Selected model: I747M Selected port: COM138 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SGH-I747M Android version: 4.3 Product code: Not Active Phone version: I747MVLUEMK5 PDA version: I747MVLUEMK5 CSC version: I747MOYBEMK5 IMEI: Unknown Phone S/N: R21CB2RAWPE Checking Super user right... true Backuping MMCBLK... OK Checking phone at COM138 Backuping NVM... OK Writing data to phone... OK Rebooting phone... OK Waiting phone... OK Bypass MSL... OK Repairing... OK Checking phone at COM138 Restoring NVM... OK Reseting... OK Repair done Done with Samsung Tool v.17.0 IMEI Done |
03-02-2014, 14:09 | #22 (permalink) |
No Life Poster Join Date: Oct 2008 Location: Bangladesh
Member: 881225 Status: Offline Sonork: 100.1678282 Thanks Meter: 80 | Selected model: I747M Selected port: COM10 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Searching ADB device... OK Reading phone info... Model: SGH-I747M Android version: 4.3 Product code: Not Active Phone version: I747MVLUEMK5 PDA version: I747MVLUEMK5 CSC version: I747MOYAEMK5 IMEI: Unknown Phone S/N: 00000000000 Checking Super user right... true Backuping MMCBLK... OK Writing data to phone... OK Reseting EFS... OK Rebooting phone... OK Waiting phone... OK Bypass MSL... error Done with Samsung Tool v.17.0 Done with Samsung Tool v.17.0 hepl plz |
03-04-2014, 08:05 | #23 (permalink) | |
No Life Poster Join Date: Jul 2007 Location: UK Age: 45
Member: 553000 Status: Offline Thanks Meter: 2,302 | Quote:
03-07-2014, 03:49 | #29 (permalink) |
Member: 553000 Status: Offline Thanks Meter: 2,302 | I am confused everything was same in my situation I hv already tried with 17.0 & 17.1 then why I got problem in repairing Imei. Sent from my GT-I9100 using Tapatalk |
