02-23-2015, 13:22 | #1 (permalink) |
Freak Poster Join Date: Jan 2015 Location: faisalabad
Member: 2323951 Status: Offline Sonork: 100.1668590 Thanks Meter: 86 | samsung i747 no service after unloking Please, allow USB debugging on phone... OK Reading phone info... Model: SGH-I747M Android version: 4.4.2 Product code: Not Active Phone version: I747MVLUFNE6 PDA version: I747MVLUFNE6 CSC version: I747MOYBFNE6 IMEI: Unknown Phone S/N: R28F903LFPR Bypass MSL... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool v.18.9 Selected model: I747M Selected port: COM12 SAMSUNG Mobile USB Serial Port Selected port speed: 115200 Reseting... OK Repair done Done with Samsung Tool v.18.9 |
02-23-2015, 13:51 | #3 (permalink) |
No Life Poster Join Date: Jan 2004 Location: Karachi, Pakistan Age: 52
Member: 50106 Status: Offline Sonork: 100.109487 Thanks Meter: 224 | check Baseband................................... |
The Following User Says Thank You to Paki Mobile For This Useful Post: |
02-24-2015, 05:06 | #7 (permalink) |
Major Poster Join Date: Jan 2015
Member: 2334540 Status: Offline Thanks Meter: 12 | Links S3 phones are never a good idea with Z3x if you dont know how to restore the qcn or rewrite nv items. I run into this issue all the time with S3 it really easy to fix. THe link below will give you all the nv items you need for most att samsung phones. Once you pick your port rewrite the nv items and then adjust apn settings and you should be fine. It will take about 2-3 minutes but it will work. Also i use 17.4 for z3x to do s3. It does not work any better but its a shorted time period then v18.9 good luck .I cant post links yet pm me if you need links |
The Following 2 Users Say Thank You to iluvny For This Useful Post: |
02-24-2015, 09:58 | #9 (permalink) |
Banned Join Date: Feb 2015
Member: 2346600 Status: Offline Thanks Meter: 31 | Omg...it would of helped if you checked the new security box in the first place. If s3 is higher than 4.1.2 you have to check that little box. and by your first post i can tell your phone is ne6 and you didnt have new security box checked. |
The Following User Says Thank You to master_of_imei For This Useful Post: |
