10-03-2012, 14:29 | #2 (permalink) | |
No Life Poster Join Date: Apr 2006 Location: Made In Brazil Age: 42
Member: 264903 Status: Offline Sonork: 1584531 Thanks Meter: 3,350 | Quote: 2. Switch phone USB connection to PC Suite on: menu>phone settings>usb mode. 3. Enable debugging on: menu>application settings>development.. 4. Connect cables and setup drivers. 5. Select Diagnostic port in port settings 6. Press Unlock SP button | |
10-03-2012, 23:31 | #5 (permalink) |
Freak Poster Join Date: Sep 2011 Location: In The World Of ALLAH & RASOOL Age: 33
Member: 1647655 Status: Offline Sonork: 100.1640928 Thanks Meter: 50 | Yeah uart cable and your phone should be unlocked |
The Following User Says Thank You to ZJ. For This Useful Post: |
12-09-2012, 02:03 | #6 (permalink) |
Freak Poster Join Date: Feb 2006 Location: UK Age: 44
Member: 232341 Status: Offline Thanks Meter: 55 | Samsung I8150T, from vodafone Au use z3x Samsung Tool software (tested with 12.6 and 13.5) but chose infinity box as the interface instead of Z3x box com, you will get the code. _______________________________________________ select z3x com, get following info: Selected model: I8150 Selected port: COM9 USB Serial Port Selected port speed: 115200 Reading phone info... no answer from phone Done with Samsung Tool v.13.5 ____________________________________ then select infinity box as the interface, get the following infomation: Selected model: I8150 Selected port: COM3 USB Serial Port Selected port speed: 115200 Reading phone info... PDA/CSC version: I8150TDULA4/I8150TVAULA1 Phone version: I8150TDULA2 Phone HW: MP 0.800 Cal date: 2012.12.08 Reading IMEI... OK IMEI: 35952xxxxx7237 Phone S/N: RVxxxxL3HA Build: M7630A-ABBQMAZM-4.0.40 Reading security... OK Bypass MSL... OK Freeze/Master code: 38262742 NET lock: 13929161 Sub lock: 00000000 SP lock: 00000000 CP lock: 00000000 For check lock status: *#7465625# Done with Samsung Tool v.13.5 Reading Phone Info... OK Phone S/N: RV1Cxxx3HA Build: M7630A-ABBQMAZM-4.0.40 IMEI: 3595xxxxxx72xx PDA/CSC Version: I8150TDULA4/I8150TVAULA1 Phone version: I8150TDULA2 Phone HW: MP 0.800 Cal Date: 2012.12.08 Read Security... OK Bypass MSL... OK Reading Codes... OK MCK: 38262742 NCK: 13929161 NSCK: 00000000 SPCK: 00000000 CPCK: 00000000 Done with Samsung Tool ver 12.6 Last edited by bfast007; 12-09-2012 at 02:10. Reason: add logs |
04-01-2013, 17:30 | #8 (permalink) |
No Life Poster Join Date: Dec 2005 Location: IN_BATTLE_FIELD.
Member: 214340 Status: Offline Thanks Meter: 906 | To day the same set came again for security code,,,code read done but not applying,,,asks for confirm password n it does not work when i put the code read by the software...its I8150Tmodel n not working i think new security ? BR |
