Samsung I827D SUCCESFULLY Unlocked 1) Select model S6500 2) Tick unlock 3) Connect phone powered on with C3300K UART cable (via com port). Here operation log: Count supported models - 319 Reading Phone Info... OK Model: SGH-I827D Country Code: TLS Cal Date: ªU Factory SW: I827DTLLE4 Unique Number: CSJ08970027C45F Memory Phone: ªU Phone S/N: R21C617QV8 Build: 76XXU-USMSKRLYM-109806 IMEI: 3530520 PDA/CSC Version: I827DTLLE4/I827DOYBLE4 Phone version: I827DTLLE4 Phone HW: REV1.0 Cal Date: 2012.06.08 Read Security... OK Bypass MSL... OK Unlocking ... OK Done with Samsung Tool ver 12.7 Then you are out of luck, anyways you can try to: 1) Use 00000000 as unlock code 2) Reset phone and then try procedure again |
Its supported now micro-uart cable: 1. Phone must be powered on. 2. Connect the phone to UART port. 3. Choose correct COM port in port settings. 4. Press "Unlock" button. micro-USB cable: 1. Phone must be powered on. 2. Type *#7284# and choise phone usb. 3. Type *#197328640#, select: Common - Diag Config - USB diag. 4. Reboot phone. 5. Connect USB cable, install drivers. 6. Select diagnostic port in port settings. 7. Press "Unlock" button. Selected model: I827 Selected port: COM336 SAMSUNG Android USB Diagnostic Serial Port (WDM) Selected port speed: 115200 Reading phone info... Model: SGH-I827D Country code: ªU Cal date: ªU Factory SW: I827DTLLE4 Unique number: CSJ08965XXXXXXX Memory phone: ªU PDA/CSC version: I827DTLLE4/I827DOYBLE4 Phone version: I827DTLLE4 Phone HW: REV1.0 Cal date: 2012.09.13 Reading IMEI... OK IMEI: 35305205XXXXXXX Phone S/N: R21C9XXXX Build: 76XXU-USMSKRLYM-109806 Reading security... OK Bypass MSL... OK Unlocking... OK Reseting... OK Unlock done Done with Samsung Tool v.13.8 |
read codes no work only direct unlock ok: Selected model: I827 Selected port: COM218 SAMSUNG Android USB Diagnostic Serial Port (WDM) Selected port speed: 115200 Reading phone info... Model: SGH-I827D Country code: ªU Cal date: ªU Factory SW: I827DTLLE4 Unique number: CSJ087152074E8F Memory phone: ªU PDA/CSC version: I827DTLLE4/I827DOYBLE4 Phone version: I827DTLLE4 Phone HW: REV1.0 Cal date: 2012.09.15 Reading IMEI... OK IMEI: 353052050496649 Phone S/N: R21C93FF9B Build: 76XXU-USMSKRLYM-109806 Reading security... OK Bypass MSL... OK Freeze/Master code: í&¦ôSìWB NET lock: §#šé Sub lock: vSÏ77Ǿà SP lock: vSÏ77Ǿà CP lock: vSÏ77Ǿà For check lock status: *#7465625# Done with Samsung Tool v.14.1 Selected model: I827 Selected port: COM218 SAMSUNG Android USB Diagnostic Serial Port (WDM) Selected port speed: 115200 Reading phone info... Model: SGH-I827D Country code: ªU Cal date: ªU Factory SW: I827DTLLE4 Unique number: CSJ087152074E8F Memory phone: ªU PDA/CSC version: I827DTLLE4/I827DOYBLE4 Phone version: I827DTLLE4 Phone HW: REV1.0 Cal date: 2012.09.15 Reading IMEI... OK Done with Samsung Tool v.14.1 |
