Old 10-06-2012, 06:09   #1 (permalink)
nifboy's Avatar
Member: 645987
Sonork: 100.1612601
Thanks Meter: 109
Samsung I827D SUCCESFULLY Unlocked
1) Select model S6500
2) Tick unlock
3) Connect phone powered on with C3300K UART cable (via com port).
Here operation log:
Count supported models - 319
Reading Phone Info... OK
Model: SGH-I827D
Country Code: TLS
Cal Date: U
Factory SW: I827DTLLE4
Unique Number: CSJ08970027C45F
Memory Phone: U
Phone S/N: R21C617QV8
Build: 76XXU-USMSKRLYM-109806
IMEI: 3530520
PDA/CSC Version: I827DTLLE4/I827DOYBLE4
Phone version: I827DTLLE4
Phone HW: REV1.0
Cal Date: 2012.06.08
Read Security... OK
Bypass MSL... OK
Unlocking ... OK
Done with Samsung Tool ver 12.7
Then you are out of luck, anyways you can try to:
1) Use 00000000 as unlock code
2) Reset phone and then try procedure again
The Following User Says Thank You to nifboy For This Useful Post:
Old 03-03-2013, 02:20   #2 (permalink)
kaledkureshi's Avatar
Member: 1450247
Thanks Meter: 25
Its supported now
micro-uart cable:
1. Phone must be powered on.
2. Connect the phone to UART port.
3. Choose correct COM port in port settings.
4. Press "Unlock" button.
micro-USB cable:
2. Type *#7284# and choise phone usb.
3. Type *#197328640#, select: Common - Diag Config - USB diag.
4. Reboot phone.
5. Connect USB cable, install drivers.
6. Select diagnostic port in port settings.
7. Press "Unlock" button.
Selected model: I827
Selected port: COM336 SAMSUNG Android USB Diagnostic Serial Port (WDM)
Selected port speed: 115200
Reading phone info...
Model: SGH-I827D
Country code: U
Cal date: U
Unique number: CSJ08965XXXXXXX
Memory phone: U
PDA/CSC version: I827DTLLE4/I827DOYBLE4
Phone HW: REV1.0
Cal date: 2012.09.13
Reading IMEI... OK
IMEI: 35305205XXXXXXX
Phone S/N: R21C9XXXX
Reading security... OK
Bypass MSL... OK
Unlocking... OK
Reseting... OK
Unlock done
Done with Samsung Tool v.13.8
Old 03-18-2013, 22:59   #3 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 749
read codes no work only direct unlock ok:
Selected port: COM218 SAMSUNG Android USB Diagnostic Serial Port (WDM)
Model: SGH-I827D
Country code: U
Cal date: U
Unique number: CSJ087152074E8F
Memory phone: U
Phone HW: REV1.0
Cal date: 2012.09.15
Reading IMEI... OK
IMEI: 353052050496649
Phone S/N: R21C93FF9B
Bypass MSL... OK
Freeze/Master code: &SWB
NET lock: #š
Sub lock: vS77Ǿ
SP lock: vS77Ǿ
CP lock: vS77Ǿ
For check lock status: *#7465625#
Done with Samsung Tool v.14.1
Model: SGH-I827D
Country code: U
Cal date: U
Memory phone: U
Phone HW: REV1.0
Reading IMEI... OK
Page generated in 0.21475 seconds with 7 queries
